Sheet Wizard broke my order entry?
I used sheet wizard to put a BAQ in Order Entry. I accidentally selected AppBuilder Panel option and added it as a custom sheet. When I removed it (By clicking the left arrow), it went away, but now I get errors when opening Order Entry. Any help would be greatly appreciated!
Edit: Here’s the BAQ. It returns total time for each individual operation in a BOM.
EZS-DP-OperationTime.baq (83.5 KB)
I have encountered something like this before, it can happen with embedded dashboards as well as Appbuilder panels.
Go into the Customization Maintenance screen
and find the customization in there.
Go to the Compile/Script Errors tab and click Selected Issue Helper
Scroll to the bottom of both the Controls tab and the Properties tab and if you see a reference to the Appbuilder panel, highlight the line and use the Delete key to remove it. I’ve usually found between 2 and 6 references depending on what I did with it before removing the panel.
You will want to click the Save Data when finished.
You might want to Export the customization to a file before making any changes, so that you can restore it if you delete something you shouldn’t have :slight_smile:
THANK YOU!
This worked perfectly exactly as you described. Gold star.
