If I posted correctly there should be a ShipAdvise.rpt in the download area.
This report depends on running the Job Traveler first (check shipping box)to
make the record selections and create .dbf files in C:\Vntgwork. You can
bail from the traveler at the print preview and then run the ShipAdvise
report. In our case I have compiled/distributed it and added it as a
"favorite" item for each user that needs it. There is a spot at the top of
the report for company logo to be added.
We run another very similar routine that creates a page of labels (2 up, 5
rows) on a laser printer similar to the "label" at the top left of the
advisor page. We stick these on everything related to the job (shop packet,
sheared material, WIP bin cards, etc...). When a bunch of travelers are
printed for jobs we immediately print shipping advisors and labels to go
along with them. Eventually I will add bar codes to the labels. If there
is interest in the label routine I will upload that too.
Todd Caughey
MIS Manager
Harvey Vogel Mfg. Co
Woodbury, MN
(651) 739-7373
Sent: Wednesday, September 13, 2000 9:21 AM
To: vantage@egroups.com
Subject: RE: [Vantage] Date format on Travelers
It sounds very interesting and I would be interested in taking a look at it.
So please do post it.
Thanks in advance,
Kathy Hambleton
Electron Energy Corporation
Sent: Tuesday, September 12, 2000 1:13 PM
To: 'vantage@egroups.com'
This is my first reply to a posting so please pardon me if I am not doing
this correctly.
I have pretty much totally rewritten the traveler as a seperate "Shipping
Advisor" report (just the shipping info) and ran into this same issue for
the releases. I found that changing the format from "System Default Short
Format" to the one listed as 03/01/1999 helped the appearance a lot. I also
noticed that the relases are not listed in ascending date order and had to
add a sort group - or in my case since I had eliminated all the other groups
- changed group #2 to be jobship.REQDATE. When changing the date field
format allow for wider display area or it will chop off right edge (if left
alligned).
BTW - Our shipping releases are so fluid and change daily on orders due to
customer requests so we developed the seperate shipping advisor in order to
not have to change the traveler as it makes its way around the shop floor.
The advisor is re-printed as needed and goes to shipping without affecting
the traveler. You have to select jobs via the traveler report (close after
preview) in order to create .dbf files in Vntgwork on the user PC but it
works well. If there is interest I will attempt to post the Crystal .rpt
file. If there is a better way to select records please advise.
Todd Caughey
MIS Manager
Harvey Vogel Mfg.
Woodbury, MN
(651) 739-7373
Todd Caughey
MIS Manager
Woodbury, MN
(651) 739-7373
Thanks in advance,
Kathy Hambleton
this correctly.
alligned).
Todd Caughey
MIS Manager
Harvey Vogel Mfg.
Woodbury, MN
(651) 739-7373
