That's a good idea. But... how do I hide that part of the tree view? I
looked in Options -> Tree View, and know how to change the labels but
don't see a way to remove a section. Tried creating a customization,
but don't see how to modify the nodes in a tree view - just remove the
entire tree view. Any suggestions? Epicor 9.05.600C.
Brian.
Of Gary Parfrey
Sent: Wednesday, December 15, 2010 9:10 PM
Subject: RE: [Vantage] Re: Slow performance with large number of Ship
To's
Doug, Brian
As a short term workaround try hiding the tree away in the UI?. You may
find it is faster as the screen does not keep rendering the tree UI when
hidden.
We have found when having large datasets in the screen, such as POs with
1000 lines the screen navigation is almost reduced to a crawl
When the tree is hidden everything navigates at a useable speed
May help?
Gary
Behalf
Of Brian Roberts
Sent: 15 December 2010 21:34
To's
We face the same issue, with one customer having over 6000 ship to
addresses.
In Vantage 9.05.600C (in testing for us), we are seeing the following
timing:
Customer Maintenance: Takes forever (over 60sec) to load that customer
because it is loading every single Ship To address into the tree & list.
Working on that customer is very slow... pauses in the 1-3 second range
when clicking, scrolling, looking at a ship to, etc. Frustrating.
Sales Order Entry: If you type in the ship to number when entering a
new order, very quick (~1 sec). Searching is also quick because it
pulls only 100 at a time (assuming you know what you're looking for).
Entering a new ship to address from the order entry screen (via right
click, Open With, Customer Ship To Entry) is also quick, because it
doesn't attempt to load any of the other ship to addresses. So the
process of entering an order (& possibly a new ship to) is nice and
quick.
I can test any other screens you're interested in, just ask.
Brian.
Behalf
Of djojmis
Sent: Wednesday, December 15, 2010 3:52 PM
Subject: [Vantage] Re: Slow performance with large number of Ship To's
Greetings Erik,
We have the exact same issue and Epicor knows about it. It has something
to do with the way forms are loaded.
I don't believe any of this is confidential - Epicor performed a test
for me on 8.03, 9.04 and 9.05 creating an order for a customer with 1000
ship tos. The difference between 8.03 and 9.05 was significant. 9.05 was
13 times faster than 8.03 when entering a one line order with 1000
releases.
So if you are set up like me, getting to that release will not be easy.
This does give me the incentive and motivation to start working my way
toward 9.05.
As far as your two questions, I don't know of any way to help for
either.
Doug Oswald
MIS
FLEETWOOD
Brian.
Of Gary Parfrey
To's
Doug, Brian
hidden.
May help?
Gary
Behalf
Of Brian Roberts
To's
addresses.
timing:
quick.
Brian.
Behalf
Of djojmis
Greetings Erik,
releases.
toward 9.05.
either.
Doug Oswald
MIS
FLEETWOOD
