You can print multiple copies and even pass a variable to identify each copy
in the header but you would have to code a wrapper in either VB or .NET to
do so. If the number of copies is always constant, the process would be
completely transparent to the user. Otherwise you could code up a screen to
prompt for the number of copies each time. To distribute the report, you
would need to compile it and run it from within V8 as a freestanding
executable.
Best regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
This email, and any attachments thereto, is intended only for use by the
addressee(s) named herein and may contain legally privileged and/or
confidential information. If you are not the intended recipient of this
email, you are hereby notified that any dissemination, distribution or
copying of this email, and any attachments thereto, is strictly prohibited.
If you have received this email in error, please immediately notify me by
telephone and permanently delete the original and any copy of any email and
any printout thereof.
scoobygt4uk
Sent: Wednesday, April 05, 2006 5:15 AM
Subject: Spam [Vantage] Re: Multicopies in Crystal
So what do you do to get around multiple copies of the same report?
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@...>
wrote:
Yahoo! Groups Links
executable.
Best regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
scoobygt4uk
wrote:
>would
> Only on reports that didn't include a sub-report. If the crystal guys
> say it is too difficult then I would go with that. v8 an cR10 are
> different beasts to what I have been use to.
> --- In vantage@yahoogroups.com, "scoobygt4uk" <scoobygt4uk@>
> wrote:
> > Well using Crystal myself on the standard Vantage reports I have
> > been unable to do it as the reports in question - Invoice for
> > example - already have subreports in them so you cannot use a
> > subreport within a subreport. I am no expert though so I asked a
> > specialist Crystal company to have a look and they agreed it
> > be too complicated bearing in mind the complex info on thereport.
> > Have you fiddled with any of the standard reports then and whatdo
> > you do for multicopies at your company?using
> > Martin
> > --- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@>
> > wrote:
> > > Hi,
> > > I have used vantage 6.1 and crystal 8.5. What is the issue
> athese
> > > subreport in the report footer ? You may need to modify the
> > > structure of the report. E.g. No Page Headers, but replace
> > > with groups. It should be possible , with a bit of fiddling.multipart
> > > wrote:
> > > > Hi All
> > > > A lot of you on here will hopefully got around this problem -
> we
> > > are
> > > > going live May with Vantage 8 - and presently we use
> > > formscopy,driver
> > > > for all the multitude of copies we need (customer
> > > > copy,file copy etc)for forms like Invoices,Delivery Notes etcheader
> > > > Now we are using Crystal for our reports and using A4 laser
> > > printers
> > > > instead of dot-matrix - we are trying to find a way of
> producing
> > > > multicopies of reports that are indentical except for a
> > > > indicating the copy that it is.work.
> > > > Have tried subreports in Crystal but cannot get these to
> > > > Epicor have told us about software called Altec but this isUseful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> very
> > > > expensive.
> > > > Hoping to get some good advise very very soon!
> > > > Martin Reading
> > > > IT Support Engineer
> > > > Blakley Electrics
Yahoo! Groups Links
