I hate Crystal Reports
Stephen,
Any more updates on your Crystal frustration?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, March 12, 2002 5:30 PM
Subject: RE: [Vantage] I hate Crystal Reports
Stephen, I was doing this exact thing a while ago with no problems. So that
I understand - you desire a QC sheet to print on a seperate page for each
part/assembly - correct? Do you want the QC sheet to have any
heading/footer info supplied by Crystal or only the bitmap on the page?
Does the bitmap and/or the section take up the entire printable page area?
If you desire only the bitmap on the page, try these: make sure the "keep
together" property for the bitmap AND the section are checked; check "new
page before" property for the section; suppress the Report Footer - if only
last QC sheet is getting split, the report footer is probably the culprit.
Good luck
Jim Stetter
Sent: Tuesday, March 12, 2002 5:11 PM
Yes it does. I even tried some different printer and OS still does the
same
thing.
Sent: Tuesday, March 12, 2002 6:55 PM
Subject: Re: [Vantage] I hate Crystal Reports
What I mean is: If you run the report from Vantage on a different
workstation, does it act the same way as when you run the report from
Vantage on YOUR workstation?
Troy Funte
Liberty Electronics
Sent: Tuesday, March 12, 2002 1:09 PM
The report works the same bad way when running it from Vantage. I'm
using
Crystal 8.0.
Sent: Tuesday, March 12, 2002 5:49 PM
Stephen,
This may sound like a tangent question, but it's really not. Are you
running the Job Traveler report from the computer that you designed the
report on, or is it another computer that does not have Crystal Reports
installed on it? Or does the report work the same for both computers
(when
running it from Vantage)?
Also, which version of Crystal are you using and which version of
Vantage??
8.0 or 8.5? 5.0 or 5.1?
Troy Funte
To: Vantage E groups (E-mail)
Sent: Tuesday, March 12, 2002 10:47 AM
Subject: [Vantage] I hate Crystal Reports
I know hate is a strong word but it's a lot less than some others I've
used
to describe it.
I want to add a QC sheet to print for each part or each sub-assembly
part.
I put the OLE object(bitmap image of QC sheet) in the Group Footer #2;
jobasmbl.BOMSEQ. In Crystal when I do a print preview it looks fine
and
works like it should. I save the file as a version 7. When I print a
Job
Traveler from Vantage it screws it up. It take the last QC sheet and
splits
it by printing it onto two pages with the header showing. Use the
following
code in the selection expert to suppress a header.
(PageNumber = TotalPageCount) OR ({jobasmbl.PARTNUM}
<>Next{jobasmbl.PARTNUM})
It works fine when opened in Crystal but not when printed from
Vantage.
What's up with this?
and
have
and
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
ADVERTISEMENT
and
have
ADVERTISEMENT
ADVERTISEMENT
I know hate is a strong word but it's a lot less than some others I've used
to describe it.
I want to add a QC sheet to print for each part or each sub-assembly part.
jobasmbl.BOMSEQ. In Crystal when I do a print preview it looks fine and
works like it should. I save the file as a version 7. When I print a Job
Traveler from Vantage it screws it up. It take the last QC sheet and splits
it by printing it onto two pages with the header showing. Use the following
It works fine when opened in Crystal but not when printed from Vantage.
I know I am new to the group, but I loath Crystal as well.� I have nothing
new to add at this time hehe.� I have been a vantage user since 2.0, when I
worked at Progressive Industries, and I am thankful to be able to join your
group.
Sincerely,
Daniel C. Spoerl
Estimator/MIS
Toledo Metal Spinning Co.
Phone: (419) 535-5931 ext. 203
Fax:��� (419) 535-0565�
Personal E-fax: (707) 897-1708�
Email:��� HYPERLINK
"mailto:dans@..."dans@...
WebSite: HYPERLINK
"http://www.toledometalspinning.com/"http://www.toledometalspinning.com
HYPERLINK "http://www.toledometalspinning.com/products_configurator.htm" \n
Sent: Tuesday, March 12, 2002 1:47 PM
to describe it.
jobasmbl.BOMSEQ.� In Crystal when I do a print preview it looks fine and
works like it should.� I save the file as a version 7.� When I print a Job
Traveler from Vantage it screws it up.� It take the last QC sheet and splits
it by printing it onto two pages with the header showing.� Use the following
Useful links for the Yahoo!Groups Vantage Board are: ( Note:� You must have
Crystal Reports and other 'goodies', please goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/files/."http://groups.yahoo.com/group
/vantage/files/.�
(2) To search through old msg's goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/messages"http://groups.yahoo.com/grou
p/vantage/messages
(3) To view links to Vendors that provide Vantage services goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/links"http://groups.yahoo.com/group/v
antage/links
Your use of Yahoo! Groups is subject to the HYPERLINK
"http://docs.yahoo.com/info/terms/"Yahoo! Terms of Service.
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.332 / Virus Database: 186 - Release Date: 3/6/2002
Outgoing mail is certified Virus Free.
Are you sending it to a dot-matrix printer? I had Crystal once upon a time
tell me that the print engine they use will cause funny results on a
dot-matrix printer.
Dan Shallbetter
States Electric Mfg.
Sent: Tuesday, March 12, 2002 12:47 PM
to describe it.
Nope, we're using laser HP6P.
Sent: Tuesday, March 12, 2002 1:38 PM
To: 'vantage@yahoogroups.com'
dot-matrix printer.
Dan Shallbetter
to describe it.
Stephen,
This may sound like a tangent question, but it's really not. Are you running the Job Traveler report from the computer that you designed the report on, or is it another computer that does not have Crystal Reports installed on it? Or does the report work the same for both computers (when running it from Vantage)?
Also, which version of Crystal are you using and which version of Vantage?? 8.0 or 8.5? 5.0 or 5.1?
Troy Funte
to describe it.
The report works the same bad way when running it from Vantage. I'm using
Crystal 8.0.
Stephen,
Troy Funte
used
to describe it.
splits
following
What I mean is: If you run the report from Vantage on a different workstation, does it act the same way as when you run the report from Vantage on YOUR workstation?
Troy Funte
Liberty Electronics
Crystal 8.0.
Stephen,
Troy Funte
used
to describe it.
splits
following
ADVERTISEMENT
Yes it does. I even tried some different printer and OS still does the same
thing.
Troy Funte
Liberty Electronics
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
Job
splits
following
and
have
ADVERTISEMENT
Try copying your crpe32.dll and crpaig80.dll from your Crystal developer
workstation and then putting them into the Vantage\DLL directory. You will
also need to create a copy of the crpaig80.dll as crpaig32.dll. Most of the
time when errors occur like the one that you have described is that the
crpe32.dll file on the developer station is newer then the one that Vantage
is using.
Hope this helps,
Ted Kitch
ted@...
Sent: Tuesday, March 12, 2002 4:11 PM
thing.
Troy Funte
Liberty Electronics
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
Job
splits
following
and
have
<http://docs.yahoo.com/info/terms/>
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.3328688.1261774/D=egroupweb/S=17050071
83:HM/A=847665/R=0/*http:/ads.x10.com/?bHlhaG9vbW9uc3RlcjcuZGF0=1015971084%3
eM=215002.1818248.3328688.1261774/D=egroupweb/S=1705007183:HM/A=847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002.1818248.3328688.1261774/D=egroupmai
l/S=1705007183:HM/A=847665/rand=262792327>
<http://docs.yahoo.com/info/terms/> Terms of Service.
Good luck
Jim Stetter
same
thing.
Troy Funte
Liberty Electronics
using
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
and
Job
splits
following
Vantage.
and
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
Thanks Ted, that's what I was trying to get at... DLL problems (mismatches) between Crystal and Vantage.
Troy Funte
Liberty Electronics
Sent: Tuesday, March 12, 2002 5:24 PM
is using.
Hope this helps,
Ted Kitch
ted@...
thing.
Troy Funte
Liberty Electronics
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
Job
splits
following
and
have
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
I replaced the files and the Job Traveler comes up like it should. I
shouted "Yea baby!!!" and all that. Then I hit the print button and
excitedly went down to the printer. Nothing comes. I go back to my
workstation and print again. Nothing. Then my phone starts ringing off the
hook with people that can't print sales orders, packing slips, ect... I put
the old files back and everything is back like it was.
Sent: Tuesday, March 12, 2002 4:39 PM
Troy Funte
Liberty Electronics
will
the
Vantage
is using.
Hope this helps,
Ted Kitch
ted@...
same
thing.
Troy Funte
Liberty Electronics
using
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
and
Job
splits
following
Vantage.
and
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
have
ADVERTISEMENT
If you check the archives you will find what I went thru with crpe32.dll.
Vantage could not use the newer dll if I recall.
Mark
Sent: Wednesday, March 13, 2002 12:35 PM
Subject: RE: [Vantage] I hate Crystal Reports(even more)
Troy Funte
Liberty Electronics
will
the
Vantage
is using.
Hope this helps,
Ted Kitch
ted@...
same
thing.
Troy Funte
Liberty Electronics
using
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
and
Job
splits
following
Vantage.
and
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
have
ADVERTISEMENT
Stephen,
What I had to do yesterday on a machine that couldn't run our modifed Poform.rpt report was to... Install Crystal on that machine, then uninstall it -- but leave all the .dll files intact. I know you don't want to have to do this to every machine that uses ODBC, but you might have to. Just the fact that the report runs on your computer (with Crystal) but not on the others points to this idea. If someone could pinpoint the EXACT .dll files to move, then that would be more simple. I'm pretty sure they all need to be in the c:\windows\system folder. The question is: which ones, and what version of each?
Troy Funte
Liberty Electronics
To: vantage@yahoogroups.com <vantage@yahoogroups.com>
Date: Wednesday, March 13, 2002 12:35 PM
Troy Funte
Liberty Electronics
will
the
Vantage
is using.
Hope this helps,
Ted Kitch
ted@...
same
thing.
Troy Funte
Liberty Electronics
using
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
and
Job
splits
following
Vantage.
and
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
have
ADVERTISEMENT
ADVERTISEMENT
Simply running the setup utility for a crystal 8 compiled report would
probably distribute the necessary dll's.
I'm wondering, had the machine that couldn't run the poform report been
running any compiled reports?
Thaddeus
Sent: Tuesday, March 12, 1996 10:58 AM
Subject: Re: [Vantage] I hate Crystal Reports(even more)
Stephen,
version of each?
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
will
the
Vantage
is using.
Hope this helps,
Ted Kitch
ted@...
same
thing.
Troy Funte
Liberty Electronics
using
Crystal 8.0.
Stephen,
(when
Vantage??
Troy Funte
used
to describe it.
part.
and
Job
splits
following
Vantage.
and
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
have
ADVERTISEMENT
ADVERTISEMENT
