Hello all,
We have a user that wants to confirm some pcs but we are getting this error message
Application Error
Error Detail
Message: Specified argument was out of the range of valid values.
Parameter name: Specified argument was out of the range of valid values.
Parameter name: Position is greater than number of delimited values
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at Epicor.Utilities.StringExtensions.Entry(String sourceString, Int32 index, Char delimiter) in C:_Releases\ICE\ICE3.2.200.7\Source\Shared\Framework\Epicor.ServiceModel\Utilities\StringExtensions.cs:line 134
at Erp.Internal.Lib.AdjShopL.RemoveLoad(Decimal HoursToRemove, Boolean IP_WhatIf, JobOper JobOper) in C:_Releases\ERP\UD10.2.200.7\Source\Server\Internal\Lib\JobOperShared\AdjShopL\adjshopl.cs:line 1554
at Erp.Internal.Lib.AdjShopL.Update_ResourceTimeUsed(JobOper JobOper, JobOper OldJobOper) in C:_Releases\ERP\UD10.2.200.7\Source\Server\Internal\Lib\JobOperShared\AdjShopL\adjshopl.cs:line 337
at Erp.Internal.Lib.JobOperWrite._JobOperWrite(JobOper JobOper, JobOper OldJobOper, Boolean RollUp) in C:_Releases\ERP\UD10.2.200.7\Source\Server\Internal\Lib\JobOperShared\JobOperWrite\JobOperWrite.i.cs:line 1403
at Erp.Internal.Lib.JobOperShWrite.DoJobOper(JobOper JobOper, JobOper OLDJobOper) in C:_Releases\ERP\UD10.2.200.7\Source\Server\Internal\Lib\JobOperShared\JobOperShWrite\JobOperShWrite.cs:line 1301
at Erp.Triggers.JobOper.WriteTrigger.write(JobOper JobOper, JobOper OldJobOper) in c:_Releases\ERP\RL10.2.200.0\Source\Server\Db\Triggers\JobOper\write.cs:line 231
at Ice.Triggers.TriggerQueue.ExecuteWriteTrigger(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 296
at Ice.Triggers.TriggerQueue.RunWriteTriggerInNewLevel(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord, Boolean forAddedRow) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 160
at Ice.Triggers.TriggerQueue.<>c__DisplayClass11_0.b__1() in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 148
at Ice.Triggers.TriggerQueue.RunAtNewLevel(Func1 buildTriggerRunState, Action action) in C:\_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 501 at Ice.Triggers.TriggerQueue.RunTriggers(IceDataContext context) in C:\_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 83 at Ice.IceDataContext.RunUntilAllTriggersHaveExecuted() in C:\_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 573 at Ice.Triggers.TriggerQueue.RunAtNewLevel(Func1 buildTriggerRunState, Action action) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 501
at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 329
at Ice.IceDataContext.Release[TEntity](TEntity& entity) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 269
at Erp.Triggers.LaborDtl.WriteTrigger.Write(LaborDtl LaborDtl, LaborDtl OLaborDtl) in C:_Releases\ERP\UD10.2.200.7\Source\Server\Db\Triggers\LaborDtl\Write.cs:line 1700
at Ice.TablesetBound3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1297 at Ice.TablesetBound3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 997
at Ice.TablesetBound3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 892 at Erp.Services.BO.LaborSvc.Update(LaborTableset& ds) in C:\_Releases\ERP\UD10.2.200.7\Source\Server\Services\BO\Labor\Labor.Designer.cs:line 2392 at Epicor.Customization.Bpm.MethodCustomizationBase23.RunDirectives(TParam parameters) in C:_Releases\ICE\RL3.2.200.0\Source\Server\Internal\Lib\Epicor.Customization.Bpm\MethodCustomizationBase2.cs:line 197
at Epicor.Customization.Bpm.CustomizationBase23.Execute(TParam parameters) in C:\_Releases\ICE\RL3.2.200.0\Source\Server\Internal\Lib\Epicor.Customization.Bpm\CustomizationBase2.cs:line 73 at Epicor.Customization.Bpm.BO45BFB350E259403C9B84E7766878588A.LaborSvcCustomization.Update(LaborTableset& ds) at Erp.Services.BO.LaborSvcFacade.Update(LaborTableset& ds) in C:\_Releases\ERP\UD10.2.200.7\Source\Server\Services\BO\Labor\LaborSvcFacade.cs:line 4276 at SyncInvokeUpdate(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.LaborImpl.Update(LaborDataSet ds)
at Erp.Adapters.LaborAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Erp.UI.App.TimeAndExpenseEntry.Transaction.Update()
Operation still have pcs available, job is released, it allows to confirm with 0 pcs
anyone can share some pointers?
