I wonder if anyone could give me a BAQ equivalent for the following SQL? Or a suggested avenue for this to build out some reports. This Converges 21222 rows into 131 rows (easily usable in spreadsheet too).
Dynamic SQL for PcInputValues
DECLARE @SQL NVARCHAR(max) = NULL;
SET @SQL = CONCAT('SELECT [Company],[GroupSeq],[RelatedToTableName],'
, (SELECT DISTINCT STUFF( (
SELECT DISTINCT ', ' + tt1.configFieldList
FROM
(SELECT DISTINCT CONCAT(
'min(case when [InputName] = ''',
[InputName],
''' then [InputValue] end) AS ',
[InputName] ) configFieldList
FROM [EpicorERPTest].[Erp].[PcInputValue] WHERE [Company] ='EZCUST') tt1
FOR XML PATH('')) ,1,1,'')
FROM
[InputName],
),' FROM [EpicorERPTest].[Erp].[PcInputValue] WHERE [Company] =''EZCUST'' GROUP BY [Company],[GroupSeq],[RelatedToTableName]' );
EXECUTE sp_executesql @SQL;
Yes, I remember reading that post before, but could not remember the content as such I now know that my query cannot be turned into a BAQ so thank you for that @bordway! Looks like I will need a Service Connect or something to pull the data above for finance reporting purposes. I would build out the data using the configurator choices. As there are about 150 ish configurator inputs the query above basically turns 20K lines of individual inputs into about 130 in pivot table type format relating to orders/quotes/jobs…
