Hi John,
I am still having problems trying to set up the Linked Server.
As far as the datasource when I click in that field, it has “Network name of Server”. Do I need anything else?
We have SQLServer 2008 r2.
To set up the linked server it is under Server Objects.
The setup looks the same as what you have below but, I have to choose a provider.
Thank you for your help.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Hatcher, John
Sent: Thursday, May 01, 2014 5:52 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Re: SQL Server 2008 and Progress DB
Hi Cathy,
We’re using a daisy chain of SQL server systems so that we can access our Vantage and now Epicor 9 system to APM for retro indexing.
Due to the 32 bit ODBC that is the only type supported by Epicor, We have the APM system on SQL server 2012. It has a linked server pointing to our SQL server 2000 system. This in turn has a linked server pointing to our Vantage and Epicor systems.
You may not need this two layer approach so I’ll just talk about the 2000 configuration to connect to Epicor. I would recommend creating a dedicated ODBC login on your Epicor database server for use by the linked server.
1. Use mgmt. studio to connect
2. Linked servers are found under security / linked servers
3. Right click – select new linked server
a. General TAB
i. Product name: Progress OpenEdge 10.2A driver
ii. Data source: <DSname>
iii. Provider string: Database=mfgsys; port=9450; UID=<userID>; PWD=<password>
Hope this helps
John A. Hatcher CPIM
Manager of IS
Versa Products Co., Inc.
(201) 518-5948 direct
(201) 843-2400 x4148
(201) 843-2931 fax
