Cheers Jose..will do this ....Have not thought this way... thanks ever so much!
Hi all,
We know that, passing -skip as a parameter in Epicor shortcut icon, will start Epicor without checking for new updates.
I would like to mention this parameter in the default.mfgsys file (or anyother file), to avoid the autoupdate check.
i checked the default.mfgsys file, i could not find a suitable parameter for this.
any idea folks?
Add /Skip to the shortcut.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Thu, Jun 25, 2015 at 5:29 AM, jyprksh@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>Hi all,</span></p><p><span><br></span></p><p><span>We know that, passing -skip as a parameter in Epicor shortcut icon, will start Epicor without checking for new updates.</span></p><p><span><br></span></p><p>I would like to mention this parameter in the default.mfgsys file (or anyother file), to avoid the autoupdate check.</p><p><br></p><p>i checked the default.mfgsys file, i could not find a suitable parameter for this.</p><p><br></p><p>any idea folks?</p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
Jose,
thanks for your kind reply.
i m looking for a way to add the parameter at "default.mfgsys" file or anyother file located in Epicor folder.
Basically, we have 50-60 computers. time consuming to go each computer and update the shortcut.
instead,using a bespoke software - replace all computer default.mfgsys file with new deafult.mfgsys file that contains -skip parameter.
You can push out the shortcut through GPO.
On Jun 25, 2015 7:24 AM, "jyprksh@... [vantage]" <vantage@yahoogroups.com> wrote:Â<div> <p>Jose,<div><br></div><div>thanks for your kind reply.  </div><div><br></div><div>i m looking for a way to add the parameter at "<span style="word-spacing:normal;">default.mfgsys"  file or anyother file located in Epicor folder. </span></div><div><br></div><div>Basically, we have 50-60 computers. time consuming to go each computer and update the shortcut. </div><div><br></div><div>instead,using a bespoke software - replace all computer default.mfgsys file with new deafult.mfgsys file that contains -skip parameter.</div><div><br></div><div><br></div><div><br></div> </div> <div style="color:#fff;min-height:0;"></div>
