Sub process maintenance in 9.05
If you're in 700C then they've removed it from the menu and you need to re add it.
You need to create a new menu item calling Epicor.mfg.UI.subProcessEntry.dll as the program.
Hope that helps
Martin
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jeff Greenaway
Sent: 05 October 2012 23:15
Subject: RE: [Vantage] sub process maintenance in 9.05
In 9.05, I think what you are looking for is in Utilities > Process Calling
Maintenance
Regards,
Jeff
Jeff Greenaway
Consulting CIO/ERP Consultant
jeffgreenaway@...<mailto:jeffgreenaway%40cio-ondemand.com>
www.cio-ondemand.com<http://www.cio-ondemand.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Stephen Freeman
Sent: Friday, October 05, 2012 12:54 PM
To: Vantage E Group (vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>)
Subject: [Vantage] sub process maintenance in 9.05
I've made a modification in MES for it to call a customized Scheduling
board. Problem is I get the "Menu ID thedllIneed.dll is notvalid from the
MES Menu". In 9.04 I would go to Sub Process Maintenance set up the program.
In 9.05 I can't find Sub Process Maintenance. Am I just overlooking it? Is
there a different way of doing this?
This email has been scanned for email related threats and delivered safely by Mimecast.
For more information please visit http://www.mimecast.com
I've made a modification in MES for it to call a customized Scheduling board. Problem is I get the "Menu ID thedllIneed.dll is notvalid from the MES Menu". In 9.04 I would go to Sub Process Maintenance set up the program. In 9.05 I can't find Sub Process Maintenance. Am I just overlooking it? Is there a different way of doing this?
Maintenance
Regards,
Jeff
Jeff Greenaway
jeffgreenaway@...
Stephen Freeman
To: Vantage E Group (vantage@yahoogroups.com)
Â
