Josh Serwe
Wisconsin Converting Inc.
Production Planning
(920)437-6400 x 327 My extension changed!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scotty K.
Sent: Tuesday, January 28, 2014 7:55 AM
Subject: Re: [Vantage] Subcontracting Troubles
The checkbox will break up the cost elements(labor, burden, material, material burden and subcontract) for materials pulled into a job, instead of totalizing the cost in material.
It also works in Quoting(worksheet) which comes in handy when we are building complex methods.
Scott
On Mon, Jan 27, 2014 at 10:27 PM, Joshua Giese <jgiese@...<mailto:jgiese@...>> wrote:
9.05.700B. What does that checkbox do? I will confirm tomorrow if it is checked or not.
Sent from my Atari 600
From: Scotty K [scottyk537@...<mailto:scottyk537@...>]
Received: Monday, 27 Jan 2014, 21:20
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
What version are you on?
In company config | modules | production | job, there is a checkbox called "enable mfg cost elements".
I believe this functionality was added in 607?
Scott
Sent from my iPhone.
On Jan 27, 2014, at 7:26 PM, <jgiese@...<mailto:jgiese@...>> wrote:
Here is a challenge for all of you production gurus... anyone care to show their prowess? Give this process a shot and see if you can come up with something.
Multi Job Part Subcontract Job
We send Part A (76" Roll of paper) out to a subcontractor to tint. The subcontractor sends it back as Parts B (13.25" roll), C (17.75" roll), D (24.75" roll), E (30.25" roll) & F (34.75" roll). We need the Average costing to split evenly across one UOM (pounds) that is used for all lot tracked parts going into inventory. We enter the material & labor cost factors to match the actual pounds going to inventory. We use a similar process for jobs that we do in house with labor instead of subcontract and the costing comes out.
Here is our current process:
Create a job for Part B at a quantity of 1,100 lbs. (2 lots)
Add a job part for Part C at a quantity of 1,300 lbs. (2 lots)
Add a job part for Part D at a quantity of 2,250 lbs. (3 lots)
Add a job part for Part E at a quantity of 2,550 lbs. (3 lots)
Add a job part for Part F at a quantity of 1,900 lbs. (2 lots)
Add the subcontract operation
Add the raw material Part A at a quantity of 9,200 lbs. at a cost of $0.45/lb (there is waste... we'll just say 100 lbs for this one)
PO is entered for Parts B, C, D, E & F all separate lines linked to each job part at a cost of $0.75/lb
Raw material is issued
PO Receipt is processed
Job Receipt to Inventory is processed
Our desired result is that each job part ends up with a Unit cost of $1.205/lb (Material cost of $0.455/lb & Subcontract cost of $0.75/lb)
