Subcontractor Shipment tracker multi record select issue
Just went live on E10.2.700.20 and a user discovered that if you go into Subcontractor Shipment Tracker and do a Pack ID search and select multiple lines and click OK. The tracker only shows 1 pack id. The navigation arrows are greyed out and the drop down menu is blank. We also have a 2nd company on 10.2.300.x and it does the same thing.
Is this one of those things are working as designed, a bug or something I can fix?
