Nice! Gonna file this one away.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of pbparker
Sent: Monday, March 05, 2012 3:34 PM
Subject: [Vantage] Re: The dreaded SalesRepList field
Got it working.
Replace the line:
{Bpm/Bpm.i &OBJECT_NAME=UD14 }
with:
{bo/UD14/UD14_ds.i}
Got it working.
Replace the line:
with:
{bo/UD14/UD14_ds.i}
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "pbparker" <scrumbus@...> wrote:
> I verified all the method calls and none have changed either in name or input/output methods.
> Wish it would kick back a bit clearer of an error than 4GL stop condition with nothing further.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe Rojas <jrojas@> wrote:
> > I was the one who created this .p file.
> > It’s a good heads up to know if won’t work in 9.05 because we are upgrading soon.
> > Off the top of my head, the only reason I can think of that it would be bombing out is because Epicor changed the method calls I’m using. I would use the method directives screen to see if either the method names changed or the number or type of parameters changed.
> > Something else to try is to work with the tables directly as opposed to using the BO. I used the BO because I was practicing how to do it. From within the BPM you can use the CREATE and DELETE statements to add and remove rows.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of pbparker
> > Sent: Monday, March 05, 2012 2:59 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Looks like someone created a BPM .p file in the Yahoo files to do exactly what I'm asking for, namely separate the sales reps out into a flattened UD table.
> > Only problem is it doesn't work in 9.05. Anyone willing to look at the file in the group files/BPMs section named CallBOFromABL.zip and see if they can see what's wrong with it offhand?
> > I modified his initial method to call the .p directly and hard coded his input variables to see if that was it, but the .p file throws a 4GL error trying to validate it, so it's in there no doubt.
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "pbparker" <scrumbus@> wrote:
> > > Yeah, it's the same way in E 9.05.607B and sadly, yes we're on Progress as well now. We're looking to convert to SQL, just can't get a price quoted from Epicor on what this will cost, so we'll just look at it later if/when we implement AFR.
> > > I tried already doing some linked servers but ran into a problem on my 64bit server with the 64bit ODBC drivers and SQL 2008 so I washed my hands on that for now.
> > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Vic Drecchio" <vic.drecchio@> wrote:
> > > > I’ve done it before using SQL Views with Selects with the UNION clause. And then join the View to the SalesRep table.
> > > > Assuming you’re not a SQL user you’re pretty much screwed. (sorry)
> > > > I understand why they may have architected that field like that, but still, it’s an un-joinable field to a master table (Sales Reps). The schema really needs to change; is it like that in E9, too?
> > > > If you DO NOT have a lot of Sales Reps (<= baker’s dozen), I’ve used suppression and grouping tricks in Crystal before that get you close to what you want via a scheduled BAQ dump to CSV/XML. You just need a detail section and shared variables for each Rep to make it work. It’s a PAIN to develop and modify...
> > > > Finally, if you are a lowly Progress customer like myself, one other â€Å"out-of-the-box†thought would be to install the free version of MS SQL Server, set up your live Progress DB as a linked server and do a â€Å"SELECT INTO...†and have static data cubes (tables) in MSSQL. You could update it nightly if that works for your company. Once you â€Å"suck in†the Order tables and SalesRep table into SQL, *then* you can create some magic and either: Create a sexy ASP web dashboard from the data in SQL and/or use Crystal Reports and hit SQL instead of the BAQ or Progress.
> > > > Vic
> > > > From: pbparker
> > > > Sent: Friday, March 02, 2012 11:47 AM
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > Subject: [Vantage] The dreaded SalesRepList field
> > > > I had to go and mention it recently in a post here and sadly I've awoken the karma god.
> > > > So, now our sales manager wants a BAQ that's similar to what I did for a quote dashboard, namely show orders grouped by sales rep and industry.
> > > > I can split the field out into calculated fields, but that doesn't get me my grouping really because rep order isn't good.
> > > > Has anyone come up with a way to join the SalesRep table to OrderHed with that mess of a field?
> > > > I'm thinking the only feasible solution is to create a BPM that more or less populates a UD table with the sales rep values split. This would then require me to get special license from Progress to be able to insert rows into tables from ABL.
> > > > Anyone come up with anything else for a solution? (I really hate this field).
> > > > No virus found in this message.
> > > > Checked by AVG - www.avg.com
> > > > Version: 2012.0.1913 / Virus Database: 2114/4846 - Release Date: 03/02/12
> > > > [Non-text portions of this message have been removed]
> > Joe Rojas | Director of Information Technology | Mats Inc
> > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > jrojas@ | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
> > This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
