Changed it to the form's Shown event.
Sent: Wednesday, October 17, 2012 7:34 PM
Subject: Re: [Vantage] Time & Expense Entry from Employee Maintenance
Should be fine except if you switch Windows it may reload
On Oct 17, 2012 6:34 PM, "Ted Koch" <tkoch77@...> wrote:
> Got it. After thinking about it I guessedthat the object that was not
> instantiated was the calendar control that ProdCal.GetByID references. So
> rather than in the form load event, I used the Form.Activated event. Anyone
> see an issue with doing it this way?
>Â Â Private Sub TimeExpenseForm_Activated(ByVal sender As Object, ByVal
> args As EventArgs) Handles TimeExpenseForm.Activated
>Â Â Â Â If Not (TimeExpenseForm.LaunchFormOptions Is Nothing) Then
>Â Â Â Â Â Â If Not (TimeExpenseForm.LaunchFormOptions.ValueIn Is Nothing)
> Then
>Â Â Â Â Â Â oTrans.GetEmp(TimeExpenseForm.LaunchFormOptions.ValueIn)
>Â Â Â Â Â Â End If
>Â Â Â Â End If
>Â Â End Sub
> From: Ted Koch <tkoch77@...>
> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> Sent: Wednesday, October 17, 2012 6:00 PM
> This seems to partially work but I still get an object not set to an
> instance of an object error, but it seems to load everything except the
> production calendar?
> On form load...
> There is an oTrans method:
> oTrans.GetProdCal()
> So I tried placing this before and after oTrans.GetEmp, but doesn't seem
> to affect anything, still the error.
> Sent: Wednesday, October 17, 2012 5:33 PM
> After doing traces, these are the three methods that are called, either
> when the form loads or when you type in an employee # and then tab out...
> EmpBasic.GetByIDForTE
> Labor.GetRowsCalendarView
> ProdCal.GetByID
> From: Jose Gomez <jose@...>
> Sent: Wednesday, October 17, 2012 4:45 PM
> So it turns out that Time and Expense Entry doesn't use a Foirm Load to
> load an employee in. So the only way to do this would be with a
> Customization on Both Forms
> Button on Employee Maint
> Receiving on Time and Epexense.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez
>Â <http://www.google.com/profiles/jose.gomez> <
> http://www.twitter.com/joc85>
>Â <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
>Â <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Wed, Oct 17, 2012 at 4:34 PM, Jose Gomez <jose@...> wrote:
> > Never tried but it sounds like a challenge!
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> >Â <http://www.linkedin.com/in/josecgomez> <
> http://www.facebook.com/josegomez>
> >Â <http://www.josecgomez.com/professional-resume/> <
> > On Wed, Oct 17, 2012 at 4:31 PM, tkoch77 <tkoch77@...> wrote:
> >> Hi All,
> >> Curious if anyone has created a button or used context menu maintenance
> >> so when clicked it will open Time and Expense entry and pull in the
> current
> >> employee who is active in Employee Maintenance. I have tried it both
> ways
> >> and so far I can't get it to work.
> >> Any help appreciated,
> >> -Ted
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
>Â
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
