I would like to take a gander as well!
Adolfo
Adolfo
--- In vantage@yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> Yes, I second that. It would also be a big help for us to, although I completely understand that it must have taken you a long time to complete.
> Michael
> --- In vantage@yahoogroups.com, robertb_versa@ wrote:
> > Charles,
> > I appreciate the amount of work that must have taken.
> > I for one would like a peek at it.
> > Rob Brown
> > --- Original Message ---
> > From:"Charles Carden" <shadowcar1449@>
> > Sent:Wed 6/30/10 9:38 am
> > To:<vantage@yahoogroups.com>
> > Subj:Re: [Vantage] Re: Time Phase Report 8.03 409A
> > I also found the built in report to be totally useless, especially since you cannot run it by buyer. I have a BAQ time phase report that I wrote. It does not include PO suggestions but makes its own suggestions based on demand and usage. The report can be filtered by Plant, Buyer ID, ClassID or PlannerID. It can be filtered by Part Number as well and I suppose you could add options to select records by beginning and ending part number as well. It sorts by Plant, Buyer/Planner, Default Vendor ID, Part Number and Due Date.
> > The tables included in the BAQ are:
> > PartPlant
> > Part
> > PartDtl
> > Plant
> > PurAgent
> > Vendor
> > Person
> > PartWhse
> > JobProd
> > PORel
> > PartCost
> > I spent a considerable amout of time writing this report so in a way I am reluctant to distribute it freely but if there is enough interest I might be willing to do so. I could upload a sample of the report to the website if anyone is interested in taking a look at what it looks like.
> > Charles Carden
> > IT Manager
> > Manitex, Inc.
> > Georgetown, Texas
> > ----- Original Message -----
> > From: bw2868bond
> > Sent: Tuesday, June 29, 2010 2:31 PM
> > Subject: [Vantage] Re: Time Phase Report 8.03 409A
> > Our purchasing people wanted to be able to run a time phase report for a range of part numbers - The full report was way too many pages and one at a time was out of the question as well.
> > I created a ASP.Net web application on our internal web server (that runs service connect) to accept a start and end part number. It then gets a list of purchased parts from the part table. Each part in the returned list is then sent to the time phase web service to return the timephase data. The data is accumulated and then displayed in a .net web part datagrid. I added a button which then exports the grid in a format that Excel can use.
> > So, input a start and end part and you get back the time phase report in Excel format.
> > If you are interested I can share the solution - obviously you will have to change parameters to fit your environment, but it should give you a starting point if it would be of use....
> > The code is not commented nor is there error handling :o)
> > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > I'm looking for one too
> > > I did create something like a time phase report for a department here.
> > > It is too specialized for them and would not be of any use to you.
> > > I used MS-Access and ODBC.
> > > It took a lot more hours than I wanted to put in and it still has issues.
> > > I found I had to export all the data into Access tables and use those for the report.
> > > A direct link to progress tables was not working for me.
> > > After this exercise, I could see why Epicor hasn't converted TimePhase yet.
> > > --- In vantage@yahoogroups.com, "Don Kollmann" <dkollmann@> wrote:
> > > > Hi Everyone,
> > > > I am looking for a replacement of the timephase report since going to
> > > > to 409A Epicor inc
