Time Phased Material Report V8.03
The topic of PO suggestions raises a question here.
The Time Phased Material Report is a nice report...
...however, our users are used to seeing MRP suggestions as exceptions. The
TPMR will give us everything we're used to seeing EXCEPT messages for MRP
suggestions, that is, you won't see a part if MRP makes a suggestion but the
part doesn't fall below min, max, below zero, etc.
I thought that the "Use Suggestions in Quantity Calculation" might give us
parts with MRP suggestions but it doesn't. The only way to see parts that have
MRP suggestions is to not run the report by exception but then it's too long
to view.
How do others manage MRP suggestions?
Mark W.
