Hello,
Not sure if I am misunderstanding something about the way adapters work with forms or if this is a bug.
I am in transfer order workbench and I used their wizard to create an “after adapter method” on the workBenchAdapter.
I used a trace to see that this was being called and indeed it is because if I create a pre-processing BPM with a message box, it pops up.
However, when I put a messagebox inside the after adapter method code block in the UI form customization a message box never pops up… How can this be?
Thanks in advance for your help.
-Utah
