Dear Sir,
Would like to seek for help on my code for UBaq on update the Reject Requisition, I has create a code in BPM base update but there’s still no any response and no any error prompt, is there some one have this experience kind to advise and share?
//var context = Ice.Services.ContextFactory.CreateContext<ErpContext>();
Erp.Contracts.ReqSvcContract ReqSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.ReqSvcContract>(Db);
Erp.Tablesets.ReqTableset ReqTS = new Erp.Tablesets.ReqTableset();
int iReqNum = (int)queryResultDataset.Results[0]["Calculated_iReqNum"];
string iCurrDispatcher = (string)queryResultDataset.Results[0]["Calculated_iCurrDispatcher"];
string iRequestor = (string)queryResultDataset.Results[0]["Calculated_iRequestor"];
Guid refSysRowID = new Guid("00000000-0000-0000-0000-000000000000");
bool outBool, c, d;
string a, b;
using (var txscope = IceDataContext.CreateDefaultTransactionScope())
ReqTS = ReqSvc.GetByID(iReqNum);
ReqSvc.RDMenuFlags(iReqNum, iCurrDispatcher, out c, out d);
ReqSvc.GetReqLogList("ReqNum = '" + Convert.ToString(iReqNum) + "'", 100, 1, out c);
ReqSvc.CheckToDo(iCurrDispatcher);
if (ReqTS.ReqHead.Count > 0)
ReqTS.ReqHead[0].ReqNum = iReqNum;
ReqTS.ReqHead[0].NextActionDesc = "Reject Requisition";
ReqTS.ReqHead[0].NextDispatcherID = iRequestor;
ReqTS.ReqHead[0].StatusType = "R";
ReqTS.ReqHead[0].ReplyOption = "R";
ReqTS.ReqHead[0].ReqUserId = iCurrDispatcher;
//ReqTS.ReqHead[0].RowMod = "U";
ReqSvc.Update(ref ReqTS);
Db.Validate();
txscope.Complete();
Hi sorry maybe I can elaborate detail, my mission is using the UBaq as input for requisition number, requestor and current dispatcher as input parameter, then I create BPM base with the custom code to execute the task to reject the dispatched Requisition.
bool outBool, c, d;
string a, b;
ReqTS.ReqHead[0].NextNote = "Reject PR";
I’m not familiar with that BO, but the way you have that structured, you are only operating on the first result in the BAQ, which might not even be the correct row if you have only one, because you need to choose the updated row.
You still have stuff in there that likely does nothing as well.
This was done in notepad, so no checking, but this should probably be closer to what you need.
Thanks @klincecum , you are correct, after GetByID it return 2 rows in tableset, which i notice in during tracing option, and the standard system has chosen the second row to update instead the first, is that possible to choose after GetByID tableset, but your idea is more closer as what i need, i will try out, thanks!
Sorry for my late response, yup the standard wont work, it can be execute without error but nothing happen on the rows update, I also have no idea, for the rest on PR approval BPM which work perfectly and I has event convert in function to call in API.
The trace route has follow all the method been call, just not understand why the row still unable to change, just i notice the row update on second rows after GetByID.
