ohh..perfect Martin! it works. never thought i would do such a schoolboy mistake!
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Friday, April 26, 2013 10:37 AM
Subject: RE: [Vantage] UD Field Help
Â
Have you ran the UD Schema Update in the Admin tools after you created the UD fields? You'll need to do that before you can use them.
Regards
Martin Horton
Business Systems Manager
direct line: +44(0)1889 272250 mobile: +44 (0)7875 404841
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jyprksh@...
Sent: 26 April 2013 09:38
Subject: [Vantage] UD Field Help
hello all,
i ran out of fields in Part table. So, i extended 3 fields by creating ud table (Part_UD).
Now, I would like to access those three new fields avilable in part_ud table. how can i use it.? ....
i tried simply adding TextBox and epibinded to UD field. then i entered a data into that textbox and saved. but, its not saved in the database. similarly, i inserted a data into DB field(1 of the UD field which I binded to the textbox), but textbox didnt showed me that DB data as well.
any help please?
#NewE9Buddy #Epicor9.05
Broadcrown Ltd. Airfield Industrial Estate, Hixon, Stafford, Staffs ST18 0PF, England
tel: +44(0)1889 272200 fax: +44(0)1889 272220 www.broadcrown.com
----- This email and the information it contains is confidential and may be legally privileged. It may be read, copied and used only by the intended recipient. Internet communications cannot be guaranteed to be secure or indeed error free as information can be intercepted, corrupted, lost, destroyed, delayed and or contain viruses. Broadcrown Ltd has scanned the email for viruses but does not accept responsibility once the email has been transmitted. The receiving company should scan the email and attachments (if any) for viruses. Any views or opinions expressed within this email are not necessarily the views or opinions of Broadcrown Limited except where the sender specifically states that they are. If you have received this document in error please email the sender and delete the message from your computer without taking copies -----
Â
Regards
Martin Horton
hello all,
any help please?
