Hello,
Are UD tables available to use as needed? Are any restricted? We have a need to store data for a custom upload, and we would like to use it to load and write a BAQ against it.
Thank you
Pete
Hello,
Thank you
Pete
There are 40 “Single” level tables, plus 10 parent-child tables available.
In some cases, you may be better off using user codes if you only have a small amount of information.
The UD tables have Character (1000 char), ShortChar (50), Number, Date, and checkboxes.
The default Kinetic user interface is not the best however, the Classic is better.
This helps - Thank you!
