Hi there,
I have a customised version of the QuoteEntry screen inherited from a previous employee (Epicor 10).
Part of this includes an Ultragrid eugQuoteLines with epibinding to the QuoteDtl + QuoteDtl_UD tables.
I’ve added extra unit fields etc in UD and want to validate that the data does not have a negative value or one field does not exceed the other so was going to try and use the eugQuoteLines AfterRowUpdate, CellChange and ClickCell events.
On entering the following in the C# code
this.eugQuoteLines.ClickCell += new Infragistics.Win.UltraWinGrid.ClickCellEventHandler(this.eugQuoteLines_ClickCell);
I get the following compile errors - what am I missing ?
Error: CS1061 - line 79 (9031) - ‘Script’ does not contain a definition for ‘eugQuoteLines’ and no extension method ‘eugQuoteLines’ accepting a first argument of type ‘Script’ could be found (are you missing a using directive or an assembly reference?)
