I have a custom check box on customer screen on the ship to Tab to mark the obsolete ship to addresses as inactive. This then filter the search results in ShipTo search. The other functionality I wish to have is to untick Primary check box when address is marked as inactive. I have used an event wizard but I do not know how to access the Primary ship to checkbox from here. Should I use EpiDataView or can I change the control propertie Checked to false somehow?
If you are doing it in the form customization, probably want to change the value of the field in the EpidataView. You’ll have problems if you try to changing a value thru the control properties.
You might find some examples if you search for .BeginEdit
A BPM should work too.
Either way, you’ll probably want to make sure the from refreshes after your value is changed.
