You might want to re-deploy. Sometimes the state the dashboard is in when you deploy is what it defaults to. I try to go thru and make sure my fields are the right size and the tab I want the dashboard to open up on is where I am before I deploy.
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jayaprakash Prabhakaran
Sent: Tuesday, September 03, 2013 3:58 AM
Subject: Re: [Vantage] Re: Update-able Dashboard - ViewListPanel Customization
yes...i deployed the dashboard, created menu and launched as Dashboard Assembly...now from the menu, i run the dashboard..it is working fine...as i mentioned early that one particular column needs a larger width as it contains a long string, i tried to customized...firstly maximized the width of the column manually and saved the layout..but when i reopen it all the layouts were gone.
so, my second thought is customizing the ViewListPanel using c#.
So, I went to customization mode and found that dashboard grid is called as ViewListPanel.
At this point, I am struck. Because, I have no clue of customising Epicor.Mfg.UI.App.<dashboardName_ViewListPanel>.
From: b_ordway <bruce.d.ordway@...<mailto:bruce.d.ordway%40gmail.com>>
Sent: Monday, September 2, 2013 10:23 PM
Subject: [Vantage] Re: Update-able Dashboard - ViewListPanel Customization
Have you already deployed this and added it to the menu as an assembly? That will allow you to open it customization mode.
Brenda
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, <jyprksh@...<mailto:jyprksh@...>> wrote:
> Yes I did...but when i close and reopen the form..all the changes are reverted to old style....
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> wrote:
> >>my challenge is to set that column width to maximum size
> Have you tried Tools, Layouts, Save Layouts As Default?
> It's a low-tech option.
> Sometimes it is good enough & can save you the trouble of customizing a DB assembly.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> , jyprksh@ wrote:
> > Hi All,
> > I have a update-able dashboard, it list all the information with gridview layout. When I checked in customization mode, it says "EPICOR.MFG.UI.APP.<TESTDASH>.XXXVIEWLISTPANEL"
> > In the list, one column have a very long data. So, my challenge is to set that column width to maximum size so that users do not need to maximize it manually by dragging.
> > Is there anyone could guide me in customizing VIEWLISTPANEL which reside with dashboard.
> > cheers all..
