When you go from 8.00.808 to 8.03.304 is this a complete new install or is it a revved up Service Pack/Patch 'upgrade'?
Thanks for any info....
Melissa
Todd Hofert <
todd@...> wrote:
Install 8.03 using the same instance of Open Edge.
Restore the backup exactly as I outlined in previous e-mail on this
subject. I omitted one step in previous instructions and that was to
copy your backup file into the same directory as your target database.
Then the syntax will work properly.
I don't recall whether or not database conversions or schema changes
were required but you could try to run schema change after the restore.
It will tell you if it is necessary or not. Then open Admin Tools, if db
conversions are required they will run automatically. Then log in.
Todd
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of adamtuliper
Sent: Tuesday, October 10, 2006 12:32 PM
To:
Subject: [Vantage] upgrade 8.0 db to 8.3
Whats the upgrade procedure for an 8.0.808 to 8.3 db?
IE have an 8.0 backup and want to install an 8.3 instance and restore
to it. Whats the conversion process for this?
Is it safe to have the 8.3 install use the same c:\epicor\oe100b
directory? I would imagine so since that version of progress is the
same, but just want to make sure.
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Melissa Hietala
UMC, Inc.
melissah@...
Get your email and more, right on the new Yahoo.com
