Using a Customized field in a BPM
I have spend almost all the day looking alternatives:
I created a Customized Field in the Employee table (EmpBasic).
When the user is created, we need to add a record in the Warehouse Bin table (WhseBin) for an specific warehouse created for employees. To do it, I am trying to create a BPM in Employee.Update.
I have the next code:
bool bExists = false;
string sTOOLSEMP = "TOOLSEMP";
using (var txscope = IceDataContext.CreateDefaultTransactionScope())
  foreach(var ttEmpBasic_iterator in(from ttEmpBasic_Row in ttEmpBasic select ttEmpBasic_Row))
    var ttEB = ttEmpBasic_iterator;
    foreach (var tWhseBin in Db.WhseBin.Where( tWhseBin => tWhseBin.Company == Session.CompanyID && tWhseBin.WarehouseCode == sTOOLSEMP && xWhseBin.BinNum == ttEB.ClockNo_c))
      bExists = true;
      xWhseBin.ZoneID = ttEB.WhseZone_c;
    if (!bExists)
      // Add row
      WhseBin newRow = new WhseBin();
      Db.WhseBin.Insert(newRow);
      newRow.Company = Session.CompanyID;
      newRow.WarehouseCode = sTOOLSEMP ;
      newRow.EmpID_c = ttEB.EmpID;
      newRow.BinNum = ttEB.ClockNo_c;
      newRow.Description = ttEB.Name;
      newRow.ZoneID = ttEB.WhseZone_c;
  Db.Validate();
  txscope.Complete();
I receive the error:
1.
"EmpBasicRow" doe snot contain a definition for ClockNo_c and no accesible extension method 'ClocKNo_c' accepting a first argument of type 'EmpBasicRow' could be found (are you missing a using directive or an assembly reference?)
2.
"EmpbasicRow" doe snot contain a definition for WhseZone_c and no accesible extension method 'WhseZone_c' accepting a first argument of type 'EmpBasicRow' could be found (are you missing a using directive or an assembly reference?)
Those two fields with the error are customized fields. I just entered Constants to test it and the record is saved, but the custom fields are not recognized.
This is weird because those fields are listed to be used in a Show Message and the values are displayed.
Thank you for your comments,
@ggrimaldo I think you need to use UDField and SetUDField.
myTTRecord.UDField<string>("MyField") // Will Return the value of the field
myTTRecord.SetUDField<string>("MyField",myValue); // Will Set it
I think this will work.
newRow.SetUDField("EmpID_c",ttEmpID);
newRow.BinNum = ttEB.UDField<string>("ClockNo_c");
It’s because you’re trying to access UD fields by an object reference in the tt tables. You can’t access UD fields like this directly (“table.UDField”), so instead access them like this:
ttEB[“ClockNo_c”]
ttEB[“WhseZone_c”]
Thank you Mathew.
It allows to save. It compiles, but when I run it, I receive the message that needs to be converted from Object to String.
I just tried:
newRow.BinNum = ttEB[“ClockNo_c”].ToString();
But it didn’t work and I just changed to:
newRow.BinNum = Convert.ToString(ttEB[“ClockNo_c”]);
but I receive the next error message:
LINQ to Entities does not recognize the method ‘System.String ToString(System.Object)’ method, and this method cannot be translated into a store expression.
I am looking an alternative to solve this. Thank you very much!
Ready.
I just defined variables as string and assigned the values to the variables.
string sClockNo;
sClockNo = ttEB[“ClockNo_c”].ToString();
newRow.BinNum = sClockNo;
Thank you very much for your help!
