Access to a Custom Field in the BPM
A custom field (“CheckBox21”) was added to the table OrderRel. If I call or use that field ttOrderRel.CheckBox21 in BPM logic I get an error :
System.Drawing.Bitmap CS1061 ‘OrderRelRow’ does not contain a definition for ‘CheckBox17’ and no extension method ‘CheckBox21’ accepting a first argument of type ‘OrderRelRow’ could be found (are you missing a using directive or an assembly reference?)
However if I switch the code to Db.OrderRel I get not errors … Why is that ? are custom fields not allowed to be used in the temporary tables ?
Sample code:
foreach (var OrderRel_iterator in (from OrderRel_Row in ttOrderRel
where string.Compare(OrderHeaderXRow.Company, OrderRel_Row.Company, true) == 0 &&
OrderHeaderXRow.OrderNum == OrderRel_Row.OrderNum &&
OrderDetailXRow.OrderLine == OrderRel_Row.OrderLine
select OrderRel_Row))
var OrderRelXRow = OrderRel_iterator;
if (OrderRelXRow != null)
this.PublishInfoMessage(“OrderRelXRow:” + OrderRelXRow.CheckBox21 , Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, “PreRELEASE2”, “PreRELEASE2”);
that code will not work but the below code will work
  foreach (var OrderRel_iterator in (from OrderRel_Row in Db.OrderRel
If you look close all I did was to replace ttOrderRel with Db.OrderRel
PLEASE HELP
I think there may be a ttOrderRel_UD. I feel like i’ve seen that table pop-up when in the BAQ BPM designer.
A couple of things. Please wrap code in so it will format. I think the below will work.
Greg
ttOrderRel.["CheckBox21"]
I haves used that table and got more errors, Therefore, that’s not the one. I could be a reference or something. I just hope someone can explain why is this happening
Greg, that did not work either.
// TEST
this.PublishInfoMessage(“OrderRelXRow:” + OrderRelXRow.CheckBox17 , Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, “PreRELEASE2”, “PreRELEASE2”);
I have no problem accessing the any field in the ttOderRel but the added fields are not allowed to be selectect for some reason when I use the query to a variable
System.Drawing.Bitmap CS1061 ‘OrderRelRow’ does not contain a definition for ‘CheckBox17’ and no extension method ‘CheckBox17’ accepting a first argument of type ‘OrderRelRow’ could be found (are you missing a using directive or an assembly reference?)
I got it Greg, (bool) OrderRelXRow[“CheckBox17”] when in a variable dataset is (bool) OrderRelXRow[“CheckBox17”]…
Thanks a lot GREG…
