james
(James Howard)
May 15, 2019, 8:49pm
1
Is this possible? I can use buttons with an EpiUltraGrid to change the GroupBy, Expand, Collapse, etc, but can’t seem to do it with a DashboardUltraGrid. I included a “using Ice.UI.Dashboard; ”, but on trying to initialize I get the error: ‘Ice.UI.Dashboard.DashboardUltraGrid’ is inaccessible due to its protection level.
Edit: I tried to add the customization after deployment. Same error using a DashboardUltraGrid. Initializing the grid as a an epiUltraGrid compiles, but on the event errors on a bad Guid even though the Guid was correct. : Message:
Exception has been thrown by the target of an invocation.
Inner Exception Message: Control with specified EpiGuid property does not exist.
csm.GetNativeControlReference(“c452b038-71d8-4b88-b022-1d75ab885286”)
Program: CommonLanguageRuntimeLibrary
Method: InvokeMethod
The dashboard is actually assigning a new GUID every time the form is loaded, which is unlike the behavior in other assemblies. I must be doing something horribly wrong.
Are you turning the dashboard into an assembly (smart client)? If not, you want to do that and place the customization on top of that.
james
(James Howard)
May 16, 2019, 12:58pm
3
That’s what I tried in the second attempt, but can’t figure out why the assembly is assigning a new guid every time. I’m going to rebuild from scratch to see if the error goes away.
james
(James Howard)
May 16, 2019, 4:08pm
4
Starting from scratch worked. I’ve learned my lesson not to attempt using the “Customize Tracker View” option in the Dashboard designer.
Here’s some free code FFR, with everything needed to buttonize the UltraGrid GroupBy and Expand/Collapse behaviors:
// Custom code for MainController
// Created: 16-May-2019 10:09:45
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
public class Script
this.epiButtonExpand.Click += new System.EventHandler(this.epiButtonExpand_Click);
this.epiButtonGBjobnum.Click += new System.EventHandler(this.epiButtonGBjobnum_Click);
this.epiButtonGBasmpartnum.Click += new System.EventHandler(this.epiButtonGBasmpartnum_Click);
this.epiButtonGBmtlpartnum.Click += new System.EventHandler(this.epiButtonGBmtlpartnum_Click);
this.epiButtonGBrem.Click += new System.EventHandler(this.epiButtonGBrem_Click);
this.epiButtonCollapse.Click += new System.EventHandler(this.epiButtonCollapse_Click);
this.epiButtonExpand.Click -= new System.EventHandler(this.epiButtonExpand_Click);
this.epiButtonGBjobnum.Click -= new System.EventHandler(this.epiButtonGBjobnum_Click);
this.epiButtonGBasmpartnum.Click -= new System.EventHandler(this.epiButtonGBasmpartnum_Click);
this.epiButtonGBmtlpartnum.Click -= new System.EventHandler(this.epiButtonGBmtlpartnum_Click);
this.epiButtonGBrem.Click -= new System.EventHandler(this.epiButtonGBrem_Click);
this.epiButtonCollapse.Click -= new System.EventHandler(this.epiButtonCollapse_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void epiButtonExpand_Click(object sender, System.EventArgs args)
EpiUltraGrid myGrid = (EpiUltraGrid)csm.GetNativeControlReference("b204b568-7d7a-4ec2-acb1-4143a9f1a4a2");
myGrid.Rows.ExpandAll(true);
private void epiButtonGBjobnum_Click(object sender, System.EventArgs args)
myGrid.DisplayLayout.ClearGroupByColumns();
myGrid.DisplayLayout.ViewStyleBand = ViewStyleBand.OutlookGroupBy;
myGrid.DisplayLayout.Bands[0].SortedColumns.Add("JobAsmbl1_JobNum", false, true);
private void epiButtonGBasmpartnum_Click(object sender, System.EventArgs args)
myGrid.DisplayLayout.Bands[0].SortedColumns.Add("JobAsmbl1_PartNum", false, true);
private void epiButtonGBmtlpartnum_Click(object sender, System.EventArgs args)
myGrid.DisplayLayout.Bands[0].SortedColumns.Add("JobMtl_PartNum", false, true);
private void epiButtonGBrem_Click(object sender, System.EventArgs args)
private void epiButtonCollapse_Click(object sender, System.EventArgs args)
myGrid.Rows.CollapseAll(true);
