I've never done it, but I think you need to got to each Crystal Report and select the Report/Verify Database option and make sure the report is pointing to the right databese. But I could be way off, too.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
To: vantage@egroups.com
Sent: Tuesday, December 26, 2000 12:15 PM
Subject: [Vantage] V 4.0 prowin32 Error - help
We have currently upgraded to version 4.0, the software appears
intact, although whenever I attempt to print a crystal report in
Vantage it initiates the print, then the workstation hangs, and I get
a prowin32 error.
Any help would be appreciated. We can't operate at this point. This
appears to be happening on all reports.
eGroups Sponsor
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
