At 12:52 PM 8/15/2000 , you wrote:
it, and it does not (!) give the full instructions on updating forms. In
addition to what it says there, you need to open each report you have
modified in Crystal, and do a Database / Verify Database operation on it,
and save it. Some of the field names and sizes are changed, and this "re
syncs" the report with the data structure. Should fix your errors right away.
But... to really do it right, you should start over with the stock 4.0
form, and re-do your mods from there. Some of the forms, particularly the
PO have some major changes to the .DBF files and you might not be printing
correct data (the misc charges on POs come to mind.) I'd kept some notes
in the Crystal summary info about my mods, but went back and thoroughly
compared my form to the 3.0 ones, took GOOD notes this time, then changed
the 4.0 forms.
-Wayne
>Report Builder reports seem to work fine. The problem is with CrystalDid you do the updates outlined in appendix C of the guide? I just re-read
>Custom forms. This is affecting us only that we can't print:
the 4.0 forms.
-Wayne
