V6.1 Intra-Job Transfers
I am not sure this is the same, but we do have instances where we are
making a part (outside of the main MOM) that we produce and as it
completes, we are using the end product of that job as a material
requirement on another job. We refer to them as Masters to Subs.
The function available in Vantage is Job Receipt to Job found in
Inventory Management.
Amazingly the costs transferred are accurate. Vantage does a good
job on keeping the cost buckets from the Master (PARTTRAN), so you
can always go back to research any discrepancies. I would, however,
be careful when analyzing costs. Since the Master Job costs are
consumed in the Sub job, you cannot combine the two in analysis as
you would be double dipping.
Patty Buechler
--- In vantage@yahoogroups.com, "Ari Footlik" <ari@...> wrote:
> Occasionally we need to move WIP pieces from one job/operation to a
> completely different job/operation, which may also result in the
> part-number changing.
> Is there a proper way to accomplish this without using Quantity
> Adjustments on the jobs involved? I was looking at the "Receipts
from
> Mfg" and the "Issues/Returns" functions, but there is no "Operation"
> field listed and I wouldn't know where to look to track the
transfers.
> If we have to use the "Quantity Adjustments," is there a place to
enter
> a note as to what happened, preferably without needing to
> un-release/un-engineer the jobs and change the comments on the
> operations?
> Thanks in advance.
> --Ari
Adjustments on the jobs involved? I was looking at the "Receipts from
field listed and I wouldn't know where to look to track the transfers.
If we have to use the "Quantity Adjustments," is there a place to enter
operations?
Thanks in advance.
--Ari
