Thanks, this will surely be needed. Sorry, I should have figured it was the same as RB (being a Progress product) when you asked and could have suggested it but was too unsure about Progress routines. In RB I usually create a variable called "Tilde" = CHAR(126) in RB just for readability. Not sure if that matters as much in .p land but for anyone still writing RB it is the same seperator.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Aaron Hoyt
Sent: Tuesday, November 08, 2005 10:01 AM
Subject: RE: [Vantage] V6.1 OrderHed.SalesRepList field
Just to add to community knowledge, and incase I ever wish to search on this
again...
I used the following formula in a .p to pull the first rep out of the field.
rep = ENTRY(1, OrderHed.SalesRepList, chr(126)).
A FOR loop could be used to get each of the 5 entries if needed.
An interesting point, beware the list is ~ separated not , separated as the
Data Dictionary states, hence the need for the chr(126). Turns out "~" is
something special in Progress, so you have to use the chr() to refer to the
separator.
Good luck to others dealing with similar issues.
Aaron Hoyt
Vantage Plastics
Of Aaron Hoyt
Sent: Monday, November 07, 2005 1:51 PM
To: Vantage Group
Subject: [Vantage] V6.1 OrderHed.SalesRepList field
Just a quick question to those playing with progress/.p or similar. Do any
of you know if you can refer to the OrderHed.SalesRepList field entries
using Array methods within progress?
I should have my answer in an hour or two, but I though I would ask the
group to see if anyone could offer a quicker answer and maybe a sample bit
of code.
Aaron Hoyt
Vantage Plastics
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
-Todd C.
again...
separator.
Aaron Hoyt
Vantage Plastics
Of Aaron Hoyt
To: Vantage Group
of code.
Aaron Hoyt
Vantage Plastics
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
_____
