Thanks, Charlie. Like I thought (and like you said), we're going to use
the RMA process to bring the material back into inventory and re-ship
it.
What we've been doing up to now has been to make count-adjustments in
inventory, then open the original sales-order, increase quantities, and
ship. This, obviously, is not the right way to do it: "How could you
have had 72 pieces in inventory if you only ever made 36?"
For my tests, I've been processing the RMA and then re-opening the
closed order, opening the line, opening the release, and shipping the
material that was returned to stock per the RMA. I haven't added a new
line to the sales-order to link to the RMA - I'll have to check that out
next week.
What bugs me, though, is that on the "Shipments" information in the
Order Tracker, you don't see the receipt of the material into stock,
which would help someone visualize the actual flow (as in 1) mis-ship,
2) RMA return, 3) re-ship). Perhaps adding that new line will show us
what we want? Otherwise, we'll end up re-vamping an existing
custom-report to show RMAs on the same report as shipments, which will
be enough for our needs.
Have a great weekend!
--Ari
Of Charlie Smith
Sent: Friday, February 29, 2008 4:38 AM
Subject: RE: [Vantage] v6.10 Making Shipment & Invoice Corrections
No. Because you indicated you shipped them by way of a packing slip, the
system says they are shipped.
You will need to bring them back in through a RMA and then create a NEW
LINE on the sales order with the link to the RMA you created. The
release should NOT be 'Make Direct' if the item is a non-stock item. If
it is non-stock, you will have to override it.
Dispose of the RMA by returning them to stock. Then you can reship them
under the new line.
Create the RMA credit in the RMA processing. You can link it to the
original invoice there.
Yes the order will show that you have shipped the 200 twice. For all
intents and purposes you did. You have two packers and two invoices. You
will also recognize that the RMA is linked to the additional sales order
line and a memo would also be helpful to indicate the reasons for the
RMA line on the order. Reviewing the original invoice you will see a
credit memo attached to it.
Behalf
Of Ari Footlik
Sent: Thursday, February 28, 2008 7:28 PM
Hi, Charlie -
The issue we're running into is that sometimes we don't catch the
mistake until after the invoice posts.
Today, I used the test system to run the following workflow:
1) Ship 200 pieces
2) Generate and post invoice
This got me to the point we run into the issue.
Then:
3) Issue, process, close RMA for 200 pieces
4) Re-open sales-order, lines, and releases
5) Re-ship the 200 pieces
Now! Here's the rub! When I add a new packing-slip and select the
re-opened line-item, I see that there's already "200" in the "Shipped to
Date" fields. However, that's not really the case - we technically
haven't shipped ANYTHING, and a report of parts-shipped will be wrong!
Shouldn't I be able to clear the "Shipped-to-Date" fields so it properly
reflects the RMA?
Or are we looking at the wrong report?
Or am I just completely out of my mind?
--Ari
Behalf
Of Charlie Smith
Sent: Tuesday, February 26, 2008 8:07 PM
Art, so long as the invoice has not been posted, you can delete the
invoice and unship the packer. Fix the packer and then ship it. The
invoice will then get recreated.
Behalf
Of Ari Footlik
Sent: Monday, February 25, 2008 4:51 PM
Subject: [Vantage] v6.10 Making Shipment & Invoice Corrections
Say, for example, we manufacture 150 pieces of part number 54321, which
are supposed to be released as one shipment of 125 pieces and one
shipment of 25 pieces.
Our shipping department accidentally enters a shipment of 151 pieces (in
other words, all 150 of the actual plus an additional "typo" piece).
The error is caught after the shipment is converted to an invoice but
before it actually leaves our building.
How can we best correct this so that we can "un-invoice" the customer
(without needing a credit-memo), put 25 pieces back into inventory, and
do away with the extra "typo" piece (the 151st piece)? Do we need to
process this situation as a kind of a "return"?
Until now, Accounting would issue a credit-memo to the customer and make
another shipment of 25 pieces, so the customer gets what they want, the
dollar-values somehow work out (so says the Accounting department), but
it looks like we shipped 176 pieces, and we go crazy 2 months later
wondering where the extra 26 pieces came from!
Thanks in advance.
--Ari
it.
next week.
--Ari
Of Charlie Smith
under the new line.
Behalf
Of Ari Footlik
Hi, Charlie -
1) Ship 200 pieces
Then:
reflects the RMA?
--Ari
Behalf
Of Charlie Smith
Behalf
Of Ari Footlik
Thanks in advance.
--Ari
