V8.03.405a Ops Auto-resequence
Thanks, Charlie.
It is merely to make it easier for some of our folks to fill out time cards correctly. If one sees Seq 913, then one uses WC 913.
Dan
---- CharlieSmith <CSmith@...> wrote:
> You would have to add the set of ops and then manually change the op numbers after they are in the job operations.
> But why? A sequence number is just a sequence number, why should it matter what the number is?
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of dmaddox@...
> Sent: Tuesday, August 19, 2008 1:07 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] V8.03.405a Ops Auto-resequence
> Our shop has a canned set of ops that has to be copied into a job (obviously) BEFORE time is charged. It's usually the CAM programmer's job to do this. He adds Seq 1 for Tooling, Seq 2 for Tool Making, Seq 3 for Programming, Seq 500 for Hand Finish, Seq 550 for Assembly, and Seq 913 for Final Inspection. V8 doesn't seem to like these seq numbers & auto-resequences them to 10, 20, 30, etc, in 10-step increments. Is there a way to turn auto-resequencing "off?" Or another work-around?
> Thanks in advance,
> Dan Maddox
> Pactiv Corp
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Thanks in advance,
Dan Maddox
Pactiv Corp
Thanks in advance,
Dan Maddox
Pactiv Corp
Thanks in advance,
Dan Maddox
Pactiv Corp
Thanks in advance,
Dan Maddox
Pactiv Corp
Thanks in advance,
Dan Maddox
Pactiv Corp
