V8.03.4xx Nightly Backup
That what I thought, but when I looked there was not a file with that name. So I don't know if I ever had it or not. So I guess I will just make one. Thanks!
--- In vantage@yahoogroups.com, "Dale Dalton" <daled@...> wrote:
> Randy - It's very similar in version 8.03.xxx ; the backup utility is still
> named "mfgbkup" but its located in the \epicor\oe101b\bin folder.
> echo Running Backup for Monday...
> @echo off
> e:
> cd \epicor\oe101b\bin
> mfgbkup online e:\epicor\mfgsys803\db\mfgsys
> f:\backup\databases\backup803.Mon
> Dale Dalton
> Complete Home Concepts, Inc.
> Riverside, MO. 64150
> 816-471-6262 (Main)
> 816-777-3725 (DID)
> 816-838-7969 (Cell)
> _____
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> randyduly
> Sent: Thursday, January 07, 2010 12:18 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] V8.03.4xx Nightly Backup
> OK, so tell me where they moved the backup utility in Vantage 8. I am used
> to running "BACKMFG.BAT" from Windows Task Scheduler in Vantage 6.1. Which
> basically run the following commands:
> echo Running Backup...
> @echo on
> D:
> cd \epicor\prgs91d\bin
> mfgbkup online D:\epicor\mfgsys61\db\mfgsys D:\epicor\backup\backup.1
> Thanks.
> Randy Duly
OK, so tell me where they moved the backup utility in Vantage 8. I am used to running "BACKMFG.BAT" from Windows Task Scheduler in Vantage 6.1. Which basically run the following commands:
@echo on
D:
Thanks.
Randy Duly
Randy,
Here is the contents of my nightly backup batch file for 8.03.408B:
@echo off
Rem This is a batch file to backup your Progress 10.1B database
Rem You will need one of these files for each database you want to
backup
Rem You will need to edit the SET statements for your installation
Rem Do not edit anything other than the SET statements
Rem Edit below -----------------------------------------------
Rem set your Progress directory, using only the physical path
SET XPrgsDir=C:\epicor\oe101b
Rem set your Database file, using only the physical path
SET XDbFile=C:\epicor\mfgsys803\db\mfgsys
Rem set your backup file and backup log file, using only a physical path
SET XBackupFile=C:\backups\Live\LiveBkup.1
SET XBackupLogFile=C:\backups\Live\LiveBkupLog.wri
Rem Do Not edit below -----------------------------------------
Rem Run backup
Call %XPrgsDir%\bin\probkup online %XDbFile% %XBackupFile% >>
%XBackupLogFile%
Rem Run verification of backup
Call %XPrgsDir%\bin\prorest %XDbFile% %XBackupFile% -vp >>
%XBackupLogFile%
Rem blank the variables out, since we are finished with them
SET XPrgsDir=""
SET XDbFile=""
SET XBackupFile=""
SET XBackupLogFile=""
You may need to change the location of your database if you have moved
it to a different physical drive as we have.
Best regards,
Bill
William Hannah
Director of Finance
William Frick & Company
Direct: 847.918.7338
www.fricknet.com
Of randyduly
@echo on
D:
Thanks.
Randy Duly
William Frick & Co's SmartMarkT RFID Named to 2008 Top Ten Products List
@echo off
e:
Dale Dalton
816-471-6262 (Main)
816-777-3725 (DID)
816-838-7969 (Cell)
_____
randyduly
@echo on
D:
Thanks.
Randy Duly
> utility is still
And in Epicor 9, the default location is: "<drive>:\Program
Files\Epicor\oe101c\bin" folder. With the embedded spaces, remember to put
quotes around the command.
Mark W.
