Marc,
Pretty much the same as in V6.1. Below is the text of the .bat file I
use. Paste into a notepad doc, save as a .bat, then call it out in task
scheduler.
@echo off
rem Epicor BACKMFG.BAT created:07/98 JE - edited: 11/20/02
rem
rem This .bat script requires modification by the system administrator
rem to include the correct paths and dirctory locations.
rem
rem NOTE:
rem Drive letter of database be a physical drive, not mapped.
rem Drive letter of backup copy can be physical or mapped,
rem on server or across network.
rem
rem General syntax of BACKMFG.BAT does the following:
rem 1) Surpress screen display (echo off)
rem 2) Drive letter locating the MFGBKUP.BAT file.
rem 3) Directory path to the MFGBKUP.BAT file.
rem 4) Call of MFGBKUP to do the backup "online"
rem of c:\path\mfgsys.db database to c:\backupdir\backup.file.
rem
rem System admin should EDIT the following:
rem a) Change DRIVE LETTER to drive where
rem directory PRGS91D\BIN\MFGBKUP.BAT is located.
rem b) Verify path to Mfgsys60\prgs91d\bin and edit if necessary.
rem c) Edit drive letter and path to database location.
rem d) Edit drive letter and path to where back should be placed
rem e) Create the BACKUP directory where backup file will be placed
rem f) copy the BACKMFG.BAT file OUT of the Mfgsys60 folder and paste
rem it into any other directory were it will be called on.
rem (i.e. Backup, Prgs91d\Bin, scripts, etc.)
echo Running Backup...
@echo off
d:
cd \epicor\oe100b\bin
probkup online D:\Epicor\mfgsys803\db\mfgsys d:\epicor\dbbkup\backup.1
Todd
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Marc Honey
Sent: Tuesday, March 06, 2007 9:30 AM
To:
Subject: [Vantage] Online Backup of Vantage 8.00.810
Can someone please help me. How do I do a live backup of Vantage 8.00.x?
In
6.1 I used the sample batch files that were installed into the Mfgsys61
directory along with the MFGBKUP.TXT file for guidance on setting up the
automated nightly routine. Can someone point me in the right direction
for
finding the corresponding information for 8.00.x?
Marc
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
