V8 Webservices Problem
Thank you so much .... very helpful ... we just ran into this also ...
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> I am posting the 'fix' info in case someone else runs across this....
> There is a dll file required that is not part of a 'standard' Server 2003 R2 install. Microsoft does not consider it a 'System' file anymore and it is up to the software developer that makes use of the file to include it in their distribution........
> the needed dll is msvcr71.dll
> It is installed by lots of applications so chances are most webservices installs work fine - I was using a fresh Server install without any unecessary software.
> --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > I am hoping someone here has seen this and knows the resolution....
> > Fresh install of Server 2003 SP2, IIS, .Net 2.0, WSE 3.0
> > I copy Webservices folder from vantage db server and run the configuration app. I install Partservice. I verify virtual directory is running under .Net 2.0
> > I run http://localhost/vantageservices/partservice.asmx and get this error:
> > Server Error in '/VantageServices' Application.
> > The specified module could not be found. (Exception from HRESULT: 0x8007007E)
> > Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
> > Exception Details: System.IO.FileNotFoundException: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
> > Source Error:
> > An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
> > Stack Trace:
> > [FileNotFoundException: The specified module could not be found. (Exception from HRESULT: 0x8007007E)]
> > System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
> > System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +211
> > System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +141
> > System.Reflection.Assembly.Load(String assemblyString) +25
> > System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +32
> > [ConfigurationErrorsException: The specified module could not be found. (Exception from HRESULT: 0x8007007E)]
> > System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +596
> > System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +3479033
> > System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +46
> > System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +177
> > System.Web.Compilation.WebDirectoryBatchCompiler..ctor(VirtualDirectory vdir) +267
> > System.Web.Compilation.BuildManager.BatchCompileWebDirectoryInternal(VirtualDirectory vdir, Boolean ignoreErrors) +36
> > System.Web.Compilation.BuildManager.BatchCompileWebDirectory(VirtualDirectory vdir, VirtualPath virtualDir, Boolean ignoreErrors) +429
> > System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) +73
> > System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +580
> > System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +93
> > System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath) +48
> > System.Web.UI.WebServiceParser.GetCompiledType(String inputFile, HttpContext context) +43
> > System.Web.Services.Protocols.WebServiceHandlerFactory.GetHandler(HttpContext context, String verb, String url, String filePath) +70
> > System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig) +175
> > System.Web.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +120
> > System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
> > Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
Source Error:
Stack Trace:
> Source Error:
> Stack Trace:
