You need to edit the Target on 5.x the icons. At the end of what is there
add vantage.exe. This should take care of it. We are on 6.0 now but had
both 5.2 and 6.0 running for about 2 months.
Erica Steffens
Business Systems Analyst
Synovis IS/PE/Caribe
Sent: Monday, July 21, 2003 11:04 AM
Subject: RE: [Vantage] Vantage 6.0 and Terminal Server
Thank you, Jeremy.
They asked me to run the instocx.exe file located on p:\vantage\ocx from the
Vantage Server, from TS through the mapped drives for both 5.1 and 6.0. It
did not solve the issue. Hopefully, the next time, I will check for
individual ICA connections to make sure it works....
Mario Aguirre
Information Systems Manager
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
Sent: Monday, July 21, 2003 10:32 AM
To: 'vantage@yahoogroups.com'
I have the same problem. I also found that if I install 6.0 on a regular
client and my 6.0 test server isn't running. 5.1 bombs out. It seems that
when you install the 6.0 client the ocx dll's vantage 5.1 references is
changed to the 6.0 server. I had not noticed this behavior in previous
upgrades.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Monday, July 21, 2003 10:17 AM
Subject: [Vantage] Vantage 6.0 and Terminal Server
Has anyone had a problem of installing 6.0 in TS with 5.1 installed?
The installation for 6.0 gives you a check mark for TS installations at the
moment of installing Vantage products (I have seen them in my work station
client installations). When I tried the installation in the TS, I did not
see this option and I figured (or assumed as some say) that the installation
program must recognized the installation of Vantage 6.0 client was done in a
TS.
I signed as Administrator and run both clients - 5.1 and 6.0 together with
no problem. I found out this morning, none of the other clients could run
5.1. After having some what unsuccessful help from support, I decided to
uninstall 6.0 and re-install 5.1. Now, 5.1 is working.
Any special tips someone might have on 6.0 client installation on TS's? The
error messages repeated every 5 seconds or so saying that the Control Widget
fail to initialize.
Thank you!
Mario Aguirre
Lakin General
<http://groups.yahoo.com/group/vantage/files/<http://groups.yahoo.com/group/vantage/files/> >
<http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links<http://groups.yahoo.com/group/vantage/links> >
<http://docs.yahoo.com/info/terms/>
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=17050071<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=17050071>
83:HM/A=1663535/R=0/SIG=11ps6rfef/*http:/www.ediets.com/start.cfm?code=30504
&media=atkins> click here
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmai<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmai>
l/S=:HM/A=1663535/rand=538616028>
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705007183:HM/A=1663535/R=0/SIG=11ps6rfef/*http:/www.ediets.com/start.cfm?code=30504&media=atkins> click here
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmail/S=:HM/A=1663535/rand=247240297>
<http://docs.yahoo.com/info/terms/> Terms of Service.
This message (including any attachments) is confidential and may be privileged. If you have received it by mistake please notify the sender by return e-mail and delete this message from your system. Any unauthorized use or dissemination of this message in whole or in part is strictly prohibited. Synovis Life Technologies
Erica Steffens
Thank you, Jeremy.
Mario Aguirre
Lakin General
2865 N. Paulina
Chicago, IL 60657
Ph: 773-871-9631
Fx: 773-871-1265
upgrades.
Jeremy Leonard
IT Manager
K-T Corporation
TS.
fail to initialize.
Thank you!
Mario Aguirre
Lakin General
ADVERTISEMENT
Terms of Service.
ADVERTISEMENT
