OCX errors running Vantage on Terminal Server
We have. It started the morning I installed the 9.1C23 ad 5.10.128 patches
two weeks ago. Ours was much more of a problem. Data collection users
could not clock into a job. We eventually had to reinstall Progress on both
our database server and the terminal server. We haven't had the problem
since.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Thursday, August 22, 2002 2:37 AM
Subject: [Vantage] OCX errors running Vantage on Terminal Server
We have been running Vantage clients using a Windows 2000 terminal server
for several months now however recently we are startting to expeirience OCX
errors such as: "Specified ActiveX control is not registered, or the .OCX
file was moved from where it was registered. Error occurred in procedure:
control_load vntgmenu.w (6087)". We have seen similar OCX errors referencing
other procedures, for example this morning part tracker is unavailable due
to this problem.
We are running Vantage 5.10.128 on Progress 9.1C23, the terminal server is
running Windows 2000 server SP3 and has Progress installed locally as
recommended by Epicor.
The error messages seem to resolve themselves eventually without the need to
log everyone off and restart the terminal server however they do cause
disruption when they occur.
Has anyone else run into this sort of problem with terminal server
implementations?
Paul Oliver
Concentric Controls Ltd.
This e-Mail (and any attachments) should only be read by the intended
addressee(s) and not be relied upon without subsequent written confirmation
of its contents. Concentric Controls Ltd. accepts no liability for the
consequences of any person acting on such information prior to the receipt
of such confirmation. If you are not the intended recipient, you are not
authorised to, and must not use, disclose, copy, distribute, or retain this
message, its attachments or any part thereof. Any views or opinions
expressed are those of the author and do not necessarily reflect the
opinions of Concentric Controls Ltd.
Concentric Controls Ltd. www.concentriccontrols.com
Priory Road, Aston, Birmingham B6 7LH, UK
Tel: +44 (0)121 327 1662 Fax: +44 (0)121 328 2498
to this problem.
implementations?
Paul Oliver
