FYI - we have been running Vantage on 64 bit clients since Windows XP x64 and Vantage 5.0, other than the manual install we have had no issues. This includes Vista Business, Enterprise, Windows 7 beta and RC.
Below is an old posting for 5.0 just need to change everything for 6.1.
Did you edit the services file? No shortcuts - copy from another machine or create a shortcut to the .mfg files you need.
Here is what we do:
Vantage Drive = V
Run V:\Progress\netsetup\setup.exe
Run V:\Vantage\OCX\InstOcx.exe
Edit C:\Windows\System32\Drivers\etc\services (for example: Epic50 2500/tcp) You can find the service in the vantage.vtg (for 6.1 vantage.mfg) file, connections= -S "xxxxx", 2500 is the default port for 5.0, tcp is the protocol.
The services file needs Local Admin rights or Explicit user Rights (Domain Admin will not work - although Domain Admin can change the rights).
For Vantage Help:
For Vantage help on Windows Vista we did not have to turn off any security settings. But we did have to add some registry settings. You can copy and paste the following text into a text file and name it something like vant32hlp.reg. Then you can either double click on it to install or add it to a script.
Vista 32 bit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\ItssRestrictions]
"UrlAllowList"="N:\\vantage\\HELP\\vnhelp_enu.chm;file://;"
Vista 64 bit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\HTMLHelp\1.x\ItssRestrictions]
For ODBC:
For the older versions of Vantage we had to use the 32bit ODBC Data Source administrator located in: C:\Windows\SysWow64\odbcad32.exe. This is not the same one in "Administrative Tools".
Hth,
Jim
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of rezn0rix
Sent: Thursday, September 24, 2009 4:26 PM
To:
Subject: [Vantage] Vantage 6.1 & Windows Vista/7 (mainly 64-bit)
Hello all,
I recently had to replace someone's workstation and the system we got them is "too new (no drivers)" for Windows XP so it has Vista x64 (ugh) on it. He doesn't use Vantage that much so it's not a huge deal right now. I also had to wipe out my own machine and I love Windows 7 at home so I figured I'd experiment here at work. I installed Windows 7 x64 and I can't get Vantage 6.1 setup and working. The biggest issue is that MFGClientSetup.exe is apparently 16-bit and just won't run. From some posts on here & Googling I have managed to:
(V: is the mapped drive we use for Epicor)
- run V:\prgs91d\netsetup\setup.exe, which ran fine and gave me some hope
- run V:\mfgsys61\OCX\InstOCX.exe, which also ran fine
- run C:\Windows\SysWOW64\odbcad32.exe and add the System DSN Merant driver, test connection worked and everything seemed great
This is as far as I made it and I'm not exactly sure what I'm missing now. I was assuming/hoping that MFGClientSetup.exe is just really a script that ran other setup programs (such as netsetup's setup) which means I could run each of them myself and be OK. I'm just not sure now what other steps I am missing. It could be as simple as associating filetypes with the right program or I could be completely missing a bunch of files. Does anyone have any experience with all of this? Even if you got the Vantage client (any version I guess) running in Vista x64 the info would probably help.
Also, does anyone have any experience with MS's Virtual PC in Windows 7 and Vantage? I thought that might be an option later on for systems that support it.
Thanks everyone,
Zack
