Thanks Rob. I will give this a try.
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
the Multiple to 15, the Max to 30; and, in the Inventory section,
set Min On-Hand to 15, Max On-Hand to 30, and check of "ReOrder to
max".
any given time.
wrote:
>MRP planning section (per your example): set the Min Lot Size to 15,
> On the Part Plant Detail tab, check off "Process MRP', in the
max".
>as you will consistenly have inv asset to account for at
> Probably a good idea to make these item Stock/Non-Phantom as well
any given time.
>we
> Rob Brown
> --- On Tue, 5/27/08, c.chest c.chest@... wrote:
> From: c.chest c.chest@...
> Subject: [Vantage] Vantage 8.03.404 - MRP and job creation
> To: vantage@yahoogroups.com
> Date: Tuesday, May 27, 2008, 11:20 AM
> Is there a way to have Vantage plan to a reorder point? We are
> setting up a psuedo Kanban (can't use the Vantage Kanban because
> are using lot control). If the min is 15 and the max is 30, and Ireached
> only want to produce in quantities of 15, if I have 30 pcs in
> inventory and then get demand for 5 pcs...I don't want to see a
> suggestion to open a job for 15 pcs. This will put me over max
> inventory level. I wouldn't want to see a suggestion until I
> or went below min. Is anyone doing anything like this?
