[Vantage 8.03.410] Customization Job Entry Screen
That's kind of a tough one as all that is built into the BL... you could cheat around it with some .net code perhaps, maybe try leaving the control unbound and then create a form or control event, like when the value changes call a sub that calls the Otrans Update method, I've done stuff similar to that in the past..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of justincalbraze
Sent: Friday, May 10, 2013 10:26 AM
Subject: [Vantage] Re: [Vantage 8.03.410] Customization Job Entry Screen
A user defined field. Specifically Jobhead.Shortchar01. I'm not dead set on that though, I can make it a UD table if that will help to make it work correctly.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Rob Bucek <rbucek@...> wrote:
> What are you binding the combobox to?
> Rob Bucek
> FAX: (715)284-4084
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of justincalbraze
> Sent: Friday, May 10, 2013 9:45 AM
> Subject: [Vantage] [Vantage 8.03.410] Customization Job Entry Screen
> How can I force a ultracombobox field to be enabled even after a job is released? Similar to the way the Job Code field stays available? They want to be able to change the value as needed without having to un-check released and engineered on the jobs.
> In the same area, where would I trigger a BPM to default that field to a value? I was running the trace logging when creating the job from a Sales Order but I couldn't seem to figure out which to use.
> Thanks for any help,
> Justin
Justin
Rob Bucek
FAX: (715)284-4084
Justin
> Rob Bucek
> FAX: (715)284-4084
> Justin
