Fresh day always helps!!!
Ok, I have spent 8 hours on this today and I am still getting the same
result. Its the same thing I have done many times over. Good thing my hair is
very short or I would have pulled it out by now.
This is what I did.
1) Created a file named test.p and compiled it to test.r and saved it to the
v:\mfgsys\vbp directory.
The file simply contains the command:
MESSAGE "TEST".
2) I customized the Job Mtrl screen and added a button with the command:
RUNPROG test.r
3) I run the program and I get the message
File test.r not found.
4) If I move the program from the VBP directory I get a different message:
**"V:\mfgsys\vbp\test.r" was not found. (293)
It must be finding it because the error message changes after I put it back.
I just think there is something screwy in the Vantage world that I am not
aware of.
Any advice would be welcome.
Jeremy
This is what I did.
MESSAGE "TEST".
RUNPROG test.r
aware of.
Jeremy
set the button to:
RUNPROG VBP\TEST.R.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of jeremyrleonard@...
Sent: Tuesday, May 31, 2005 2:20 PM
Subject: [Vantage] Vantage Basic/Stupid Stupid Question
This is what I did.
MESSAGE "TEST".
RUNPROG test.r
aware of.
Jeremy
Yahoo! Groups Links
RUNPROG VBP\TEST.R.
This is what I did.
MESSAGE "TEST".
RUNPROG test.r
aware of.
Jeremy
Yahoo! Groups Links
In a message dated 5/31/2005 2:32:21 PM Central Daylight Time,
michael.podlin@... writes:
RUNPROG VBP\TEST.R.
Thanks but that didn't work either.
I get the same message.
Jeremy
RUNPROG VBP\TEST.R.
Jeremy
I have one custom program attached to a button. I used this command:
RUNPROG VBP\filename.p
I'm not able to compile it to a .r file but this works.
Hope that helps.
Jasper
From: jeremyrleonard@... [mailto:jeremyrleonard@...]
Sent: Tuesday, May 31, 2005 3:20 PM
This is what I did.
MESSAGE "TEST".
RUNPROG test.r
aware of.
Jeremy
Yahoo! Groups Links
Hope that helps.
Jasper
This is what I did.
MESSAGE "TEST".
RUNPROG test.r
aware of.
Jeremy
Yahoo! Groups Links
What do you get if you set it for the full path:
RUNPROG V:\mfgsys\vbp\test.r
Sent: Tuesday, May 31, 2005 2:41 PM
Subject: Re: [Vantage] Vantage Basic/Stupid Stupid Question
RUNPROG VBP\TEST.R.
Jeremy
RUNPROG VBP\TEST.R.
Jeremy
I get the same error.
Jeremy
Jeremy
How about if you setup the .P program as:
{vbp/vb.i}
MESSAGE "TEST".
Don't compile it, just leave it as the .P program in the VBP folder.
Then set the button to:
RUNPROG VBP\TEST.P.
Sent: Tuesday, May 31, 2005 2:54 PM
Jeremy
Yahoo! Groups Links
{vbp/vb.i}
MESSAGE "TEST".
RUNPROG VBP\TEST.P.
Jeremy
Yahoo! Groups Links
Vantage does a very frustrating thing in this area. It buffers the programs.
You have to log completely out of Vantage and get back in for it to pick up
the new program changes.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, May 31, 2005 12:57 PM
Subject: RE: [Vantage] Vantage Basic/Stupid Stupid Question
> {vbp/vb.i}
> MESSAGE "TEST".
> RUNPROG VBP\TEST.P.
> Thanks
> Jeremy
> Yahoo! Groups Links
> Yahoo! Groups Links
Jeremy -
Move the program to the ud folder.
Then change your program to call it from there.
That should fix it.
HTH,
Calvin
Jeremy
Yahoo! Groups Links
That should fix it.
HTH,
Calvin
Jeremy
Yahoo! Groups Links
Thetas where I started. I know its some stupid mistake that is right in
front of me.
front of me.
Did you solve it? What was the problem?
Sent: Wednesday, June 01, 2005 10:19 AM
front of me.
Yahoo! Groups Links
front of me.
Yahoo! Groups Links
In a message dated 5/31/2005 2:58:06 PM Central Daylight Time,
RUNPROG VBP\TEST.P.
That worked. My stupidity exists on many levels and this was just one of
them. I guess it also didn't help that I forgot to compile my Visual Basic
project into an executable.
Thanks for everyone's help,
Jeremy
RUNPROG VBP\TEST.P.
Jeremy
