Yep, me. Attached is a doc from of all people Vantage on how to..
Sent: Tuesday, May 13, 2003 10:54 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Vantage over IPSEC VPN Tunnel
Good point Cliff... I just want to make it all look seamless to the remote
users. Maybe I can make Vantage a published app? I wonder if someone has
done that before?
Paul
Sent: Tuesday, May 13, 2003 1:53 PM
Installing locally can only cause you heartache unless you need the air
miles after a patch or upgrade. Terminal services only passes characters
once you have the Super Cache setup on your Citrix server. I have a building
3 miles away on a Frame and their results are fine once connected. The
connection time is SLOW.
Cliff
Sent: Tuesday, May 13, 2003 9:57 AM
Patrick/Mark,
Thanks for the responses;
I do run Citrix, and I planned to use that as a back-up.
Re: Vantage's performance issues: I couldn't find anything on it, I guess I
will have to be creative. I wonder if it helps to install Vantage locally,
and point back to the remote server for the DB. Hopefully I can make it
workable. I'll be sure to post my notes afterwards....
Paul
Sent: Tuesday, May 13, 2003 12:35 PM
Paul:
Vantage has some performance issues when running over a VPN. You should
probably so some testing b/4 making any promises.
Sent: Tuesday, May 13, 2003 10:47 AM
Subject: [Vantage] Vantage over IPSEC VPN Tunnel
I am creating an IPSEC VPN Tunnel from VA to a 3 desk office in CO. The
main reasons are that people need to be able to browse directories, and
I
forwarding mail. As an added bonus I could give the local office in CO
the
ability to look up parts in the parts master in Vantage.
I am running a partial T-1 in VA (256K), which I will bump up to 512K.
The
CO office will more than likely be on a Comcast-at-Home type of solution
54Mbps.
Just wondering if anybody has a similar config working, and can tell me
a
bit about the performance.
TIA,
Paul
Yahoo! Groups Sponsor
< http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=1705
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=1705>
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=1705> >
007183:HM/A=1564415/R=0/*http:/www.netflix.com/Default?mqso=60164784&par
tid=3170658>
< http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egrou
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egrou>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egrou> >
pmail/S=:HM/A=1564415/rand=165168998>
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/files/> > >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
Your use of Yahoo! Groups is subject to the Yahoo!
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > >
Terms of Service.
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=17050071
<http://www.netflix.com/Default?mqso=60164797&partid=317> &partid=317
0658>
http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupmai
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupmai
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
83:HM/A=1564416/R=0/*http://www.netflix.com/Default?mqso=60164797&partid=317
0658>
l/S=:HM/A=1564416/rand=451762479>
done that before?
Paul
Cliff
Patrick/Mark,
Paul
Paul:
I
the
The
54Mbps.
a
TIA,
Paul
tid=3170658>
Terms of Service.
>83:HM/A=1564416/R=0/* http://www.netflix.com/Default?mqso=60164797
0658>
>l/S=:HM/A=1564416/rand=169224442>
0658>
