One method is to create a vntgwork directory in each person's profile
directory on the terminal server box. Then map a drive to the person's
profile directory if this is not already done. Edit the vantage.vtg file to
point to X:\vntgwork instead of c:\vntgwork and save it under a different
name, say vantagets.vtg. When running Vantage from a TS session, run this
new vtg file.
Rick Lane
Intelligent Systems Integration, Inc.
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
"Helping Business Make Intelligent Use of Technology"
Sent: Friday, May 31, 2002 11:33 AM
Subject: Re: [Vantage] Vantage & Terminal Server
Thanks for the response. Quick question: how did you create a separate
working directory for every user? Did you simply modify each user's
shortcut to point to their own
working directory?
Thanks again!
Jim Carnes wrote:
new vtg file.
Rick Lane
600 Weber Drive
Wadsworth, OH 44281
PH: 330-335-5291
FX: 330-335-7275
working directory?
Thanks again!
Jim Carnes wrote:
> I happen to love Vantage 3 topics.course that could be because we arestill
> on it.folder
> I had the exact same problem and setup. The only thing I could find that
> may have been causing the problem (it's been about 2 weeks since the last
> reported error) was that some of the users were sharing a c:\vntgwork
> when they were running Vantage. I cleared the folder out and created a<http://rd.yahoo.com/M=226014.2032696.3508022.1829184/D=egroupweb/S=17050071
> vantage-working directory for each user and the problem seems (fingers
> crossed) to have been fixed. I can't say for sure but so far so good.
> Hope that helps some..
> Jim Carnes
> IS Administrator
> Kenlee Precision Corp
> jcarnes@...
> 1700 Morrell Park Ave
> Baltimore, MD 21230
> From: api115 [mailto:api115@...]
> Sent: Friday, May 31, 2002 11:07 AM
> Subject: [Vantage] Vantage & Terminal Server
> Hi,
> We have an NT 4 box hosting Vantage 3.0, and a Windows 2000 Server
> box running the Vantage client and terminal server. However, teminal
> services clients will randomly get the following errors in succession:
> "Unknown error code 1 for attribute NAME on the CONTROL-FRAME widget"
> "Unable to set attribute NAME in widget of type CONTROL-FRAME (3131)"
> "Error occurred while creating control-frame: splitter 1
> Error performing inpage operation
> Error code: 0x80004005 (5898)"
> "**Unable to realize control-frame widget"
> I posted about this last week, but I didn't have the exact errors
> then. Some suggested running a registry fix .bat file, but that file
> specifically tels me that it must be run while the computer is booted
> into DOS, which (obviously) won't work under Windows 2000.
> What is odd about this is that it is totally random. It comes and
> goes but there isn't any pattern to it. Odd. Anyway, any help would
> be appreciated. I know Vantage 3 isn't exactly everyone's favorite
> topic. :)
> Yahoo! Groups Sponsor
> ADVERTISEMENT
>83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1022857638%3eM=22
> 6014.2032696.3508022.1829184/D=egroupweb/S=1705007183:HM/A=1000239/R=1>have
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> already linked your email address to a yahoo id to enable access. )have already linked your email address to a yahoo id to enable access. )
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
> (1) To access the Files Section of our Yahoo!Group for Report Builder andCrystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/links
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
