Larry -
We have MultiCompany with two companies set up in the same database. We are seeing parts in both companies. We have no business need to see suppliers and customers in both so those aren't set up as global, but customers worked when I was testing. I have several emails that Epicor support sent me when I first set up that I can send you if you're interested. We're in version 8.03.405.
Kirstin
Kirstin
--- In vantage@yahoogroups.com, "Larry Barriere" <larrybarriere@...> wrote:
> We have the multi-company multi-site module.
> We are trying to implement a Multi company scenarios.
> We have three Companies setup on one db.
> Company A is the Parent and company B and C are child of company A.
> In company A I have setup a Customer called "Global Customer" with the global check box checked off also did it for parts and suppliers. I would like to have company b & c to see customers, parts and suppliers from company A and link to them but I am not able to do it.
> We have very little documentation on how to setup a Multi company.
> I have called Epicor but they are of no help.
> Has anyone out there setup Multi COMPANY on the same DB and were you able to see Customers, Suppliers and Parts in all companies.
> Also could someone explain to me what "Sonic" does and it purpose. I don't believe that I installed it right and that might be my problem.
> I did run the multi company process thinking that might be the problem but it didn't help.
> Thank you for any help that you can send me.
> Larry
> barriere@...
