you must first be using multi-company functionality. Thendecide your parent and child companies. In the parent company check the global box in part maint. Initially when this is done for a group of parts you can "push" parts to the child comapny. From then on when you add a part to the parent and make it global, go to the child company and open Part maint. click on the integrations tab, part links tab, Select global parts button. Search and a list will come up, select the parts you want to be in this child company and pull them into the screen. Click the "Link Selected" button and the system will create the linked parts in the child company.
KEnt
Date: Tue, 30 Jul 2013 14:28:49 +0000
Subject: [Vantage] Global Parts
I would like to know if anyone in the user community uses the global part functionality in part maintenance. I believe it is something we would like to use but I am not able to find any information on setup or how it works using multi-company.
I'm looking for any of this information:
What company configuration needs to be set up other than the Global Table Maintenance?
When a part is created in one company, and made Global, how does it create records for other companies?
Any information that anyone could give me would be helpful.
Thanks in advance for any input!
KEnt
