What Links an Order Release to a Job?
Hi All,
Today I have a question about linking jobs and releases. When I open the sales order entry form, and choose an order with releases, then go to the Releases > Jobs tab, I can see that most of my releases do not have jobs linked to them, but sometimes one release will have a job listed.
What is the field that links these together? Is it in the OrderRel and in JobHead tables?
Thank you for your time!
Nate
The fields to link them are in the JobProd table, and the links are created via various business objects. You can use Actions > Order Job Wizard at the SO level to create the job if the release is marked as Make Direct (otherwise the wizard menu option is grayed out); and from Job Entry you can use New > Demand Link > Make to Order.
Perfect! Thank you! I don’t know how I missed that!
