Win 95 client running slow
Wayne,
Which version of Norton Utilities are you using?
I should get the one that I can run from the CD-ROM.
Mike Tonoyan / All American Products Co.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, April 05, 2002 2:28 PM
Subject: RE: [Vantage] Win 95 client running slow.
> At 12:24 PM 4/5/2002 -0800, you wrote:
> > the clients running Win 95 OS slowed down considerably. I ran
> > the "UNREGOCX.BAT" on the clients without any good results. It helped
> Like the other guys said, you got'ta remove all the registry entries
> pointing to the old server.
> Rather than the time consuming manual method, you might try the "Win
> Doctor" program in Norton Utilities. It cleans up a lot of registry junk,
> and should remove the old Vantage pointers. On the version I have, you
can
> run it directly from the CD without installing it. You'd have to read the
> fine print in the license yourself, but that *might* even save you from
> buying a copy for every PC.
> -Wayne Cox
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Hello,
I shut down the old server where Vantage 4.0 was running before. All
the Win 98 client though. I started the old server where there is a
copy of Vantage and Progress, without running the database. The speed
is up again.
Any ideas?
Mike,
The Vantage client leaves a *lot* of entries in the regestry of the
workstation. Un-installing (or running UNREGOCX.bat) does *not* clean up
those registry entries.
Launch REGEDIT. Search vor 'Vantage'. Manually change *every* entry to
point to your new server (the new mapped drive).
Yea, it's a lot of work. I've had to clean up workstations (both Win95 and
WinNT) that have had Vantage 3, 4, 5.0 & 5.1 on them. Took the better part
of an hour to clean up the registry. The system ran *much* faster then.
Malcolm Spann
MIS
Malmberg Engineering
> -----Original Message-----
> From: miket91326 [mailto:miket@...]
> Sent: Friday, April 05, 2002 11:58 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Win 95 client running slow.
> Hello,
> is up again.
> Any ideas?
> ------------------------ Yahoo! Groups Sponsor
> HOT! PRICE BREAKTHROUGH!
> SUPER Tiny Wireless Video Camera UNDER $80 BUCKS --> ORDER NOW!
> http://us.click.yahoo.com/y7toOC/8o6DAA/yigFAA/PhFolB/TM
> You must have already linked your email address to a yahoo id
> to enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
Been there, Done that, but it works...
I launched REGEDIT and just deleted "Vantage" and then reinstalled client...
Sent: Friday, April 05, 2002 3:25 PM
Mike,
Malcolm Spann
MIS
> Hello,
> is up again.
> Any ideas?
<http://us.click.yahoo.com/y7toOC/8o6DAA/yigFAA/PhFolB/TM>
> to enable access. )
<http://docs.yahoo.com/info/terms/>
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1954253.3462811.1261774/D=egroupweb/S=17050071
83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1018038312%3eM=21
5002.1954253.3462811.1261774/D=egroupweb/S=1705007183:HM/A=1000239/R=1>
<http://us.adserver.yahoo.com/l?M=215002.1954253.3462811.1261774/D=egroupmai
l/S=1705007183:HM/A=1000239/rand=828330841>
or one could more quickly delete all the registry entries containing
"Vantage" entries (which takes a repetetive combination of the f3, y, and
enter keys), and reinstall the appropriate vantage client.
Thaddeus
Sent: Friday, April 05, 2002 12:25 PM
Mike,
Malcolm Spann
MIS
> Hello,
> is up again.
> Any ideas?
> to enable access. )
and should remove the old Vantage pointers. On the version I have, you can
-Wayne Cox
Instead of searching just for "Vantage entries" you can search only the
value data (uncheck keys and values) for the old path: e.g.. vantage lives
now on X:\Vantage, but it used to be on V:\Vantage, then do a value data
search for v:\vantage.
This shows you only those keys still referring to the old location, and
thus, saves you from wearing out the F3 key on your keyboard. ;)
Sent: Friday, April 05, 2002 3:46 PM
To: 'vantage@yahoogroups.com'
Thaddeus
Mike,
Malcolm Spann
MIS
> Hello,
> is up again.
> Any ideas?
> to enable access. )
Paul,
This is partly true. Vantage/Progress puts entries in the registry pointing
to *both* the mapped drive (V:\Vantage) *and* the server name
(\\ServerName\epic51\vantage\<etc>). You'll need to change both.
If, by chance, you run a network with both NetWare and Windows, and use
NetWare's NDS4NT to simplify management (like we do), you'll learn that you
*have* to change the server name callouts to the mapped drive letter
callout, or you'll have other problems.
Malcolm Spann
MIS
> From: Paul Siebers [mailto:paul.siebers@...]
> Sent: Friday, April 05, 2002 1:29 PM
> lives now on X:\Vantage, but it used to be on V:\Vantage, then do a
> value data search for v:\vantage.
> From: Thad Jacobs [mailto:tjacobs@...]
> Manually change *every* entry to point to your new server (the new mapped
drive)
> the f3, y, and enter keys), and reinstall the appropriate vantage client.
> Thaddeus
> From: Malcolm Spann [mailto:Malcolm@...]
> Mike,
> *not* clean up those registry entries.
> *every* entry to point to your new server (the new mapped drive).
> (both Win95 and WinNT) that have had Vantage 3, 4, 5.0 & 5.1 on them.
Took
> the better part of an hour to clean up the registry. The system ran
*much*
> faster then.
> Malcolm Spann
> MIS
> > Hello,
> > is up again.
> > Any ideas?
You'll also want to delete registry entries to 8.3A, 9.0B or 9.1A if those apply to old versions of Progress on a Client -- Assuming 9.1C is your current version.
Troy Funte
Liberty Electronics
Sent: Friday, April 05, 2002 4:52 PM
Paul,
Malcolm Spann
MIS
drive)
> Thaddeus
> Mike,
Took
*much*
> faster then.
> Malcolm Spann
> MIS
> > Hello,
> > is up again.
> > Any ideas?
ADVERTISEMENT
Thank you everybody for your advise.
Sent: Friday, April 05, 2002 7:06 PM
Subject: Re: [Vantage] Win 95 client running slow.
current version.
> Troy Funte
> Liberty Electronics
> From: Malcolm Spann
> Paul,
pointing
you
> Malcolm Spann
> MIS
the
and
mapped
> drive)
client.
> > Thaddeus
> > Mike,
> Took
> *much*
> > faster then.
> > Malcolm Spann
> > MIS
> > > Hello,
helped
speed
> > > is up again.
> > > Any ideas?
> ADVERTISEMENT
