Windows Server 2008 - Task Scheduler - Progress Program
I was able to get this issue resolved thanks to a member of this group and Progress expert. Thank you Carl Peterson for your help once again with all things Progress related!
--- In vantage@yahoogroups.com, "Robert" <robert.nupp@...> wrote:
> I am trying to set up an in house written Progress Program to run on a schedule using Windows Task Scheduler in Server 2008. I have done this in the past using Server 2003 with no issues but I am not having any luck with 2008 Server.
> Here is the "Action" I am using to run prowin32.exe with the parameters to connect to our Epicor905 database and run a progress program.
> "D:\Program Files (x86)\Epicor Software\oe102a\bin\prowin32.exe" -db "D:\Program Files (x86)\Epicor Software\Epicor905\db\mfgsys.db" -S 9400 -H epicor905 -N TCP -p "D:\emods\test.p" -s 200 -B 2000 -U sysprogress -P sysprogress
> When I manually run this schedule I am getting a Failure to Launch error message and that is all it states.
> Any help on this would be a big help. Thanks
