Hi, I was install client side XL Connect on my pc. But, I get this error msg on my first time open excel. Error msg as below:
Detailed technical information follows:
Date and Time: 09/12/2020 2:17:56 PM
Machine Name: RIANA-PC
IP Address:
Current User: PANA\david
Application Domain: C:\Users\david\AppData\Local\BizInsightSuite
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Version: 4.0.0.0
Exception Source:
Exception Type: System.Runtime.InteropServices.COMException
Exception Message: Unable to create specified ActiveX control.
Exception Target Site: ForwardCallToInvokeMember
---- Stack Trace ----
System.RuntimeType.ForwardCallToInvokeMember(memberName As String, flags As BindingFlags, target As Object, aWrapperTypes As Int32[], msgData As MessageData&)
mscorlib.dll: N 0191 (0xBF) IL
AddinExpress.MSO.ICTPFactory.CreateCTP(CTPAxID As String, CTPTitle As String, CTPParentWindow As Object)
mscorlib.dll: N 00000 (0x0) JIT
AddinExpress.MSO.ADXAddinModule.AddCustomTaskPanes(parent As Object, outlookFolderName As String, showError As Boolean)
mscorlib.dll: N 0000 (0x0) IL
Before I install xl connect, I had disable pc firewall, and login as administrator. Appreciate for any reply.
